Shane56 Posted October 25, 2021 Report Share Posted October 25, 2021 Hi all, every so often the engine management light comes on the dash, and I have taken note it's using a lot more petrol than normal. I get usually the top error on my OBD but it has not thrown another error. Anybody help?? Quote Link to comment Share on other sites More sharing options...
Slammedrollerskate Posted October 25, 2021 Report Share Posted October 25, 2021 Looks like you need a new downstream o2 sensor and an egr valve. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted October 25, 2021 Author Report Share Posted October 25, 2021 Thanks for the reply, I'm pretty handy with mechanics, is this a job I can do myself?? Quote Link to comment Share on other sites More sharing options...
Slammedrollerskate Posted October 25, 2021 Report Share Posted October 25, 2021 Yea sure ,the egr is a bit fiddly but they're both easily done. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted October 25, 2021 Author Report Share Posted October 25, 2021 Thanks are the parts readily available as eoro car parts don't sell them. Quote Link to comment Share on other sites More sharing options...
mk2 Posted October 26, 2021 Report Share Posted October 26, 2021 Which model is it? Quote Link to comment Share on other sites More sharing options...
Shane56 Posted October 26, 2021 Author Report Share Posted October 26, 2021 1 hour ago, mk2 said: Which model is it? It's a lupo E 1.0 Quote Link to comment Share on other sites More sharing options...
mk2 Posted October 26, 2021 Report Share Posted October 26, 2021 O2 sensor is fine. Check for air leaks. Whats the power like? Normal power or weak? And how's it idle/start? Quote Link to comment Share on other sites More sharing options...
Shane56 Posted October 26, 2021 Author Report Share Posted October 26, 2021 Will do, the power is normal , it just seems to be using a lot of petrol at the moment. Quote Link to comment Share on other sites More sharing options...
mk2 Posted October 26, 2021 Report Share Posted October 26, 2021 (edited) Can you check the live sensor data - the temp sensors, ideally when cold before starting after overnight. Should be the same reading. Might be a dodgy temp sensor AND something else... Assuming that the temp gauge reads normal once warmed up? Edited October 26, 2021 by mk2 Quote Link to comment Share on other sites More sharing options...
Shane56 Posted October 26, 2021 Author Report Share Posted October 26, 2021 I will check that, I have noticed that the temp gauge sometimes works then it doesn't, could that be causing the problem?? Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted October 28, 2021 Report Share Posted October 28, 2021 (edited) On 10/26/2021 at 10:15 PM, mk2 said: O2 sensor is fine. Check for air leaks. Whats the power like? Normal power or weak? And how's it idle/start? OBD can show O2 sensor heater live data as well, @Shane56 check that too. Edited October 28, 2021 by ObjectiveAway Quote Link to comment Share on other sites More sharing options...
cpcpeter Posted November 17, 2021 Report Share Posted November 17, 2021 Don't buy a new EGR valve just yet. Give the thing a clean first and potentially save yourself some money. Very common for the valve to get coked up which could explain the range/performance error. Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 17, 2021 Report Share Posted November 17, 2021 My hunch is the infamous temp sensor. Especially since the guage keeps dieing. That company in Luxembourg that manufactured them really should have gone under years ago. The amount of global problems they have caused across the entire VAG group range is really unbelievable. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted November 19, 2021 Author Report Share Posted November 19, 2021 MK2 going to try tomorrow so will let you know, fingers crossed. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted November 20, 2021 Author Report Share Posted November 20, 2021 Changed the temp sensor and reset the Ecu after driving for 5 miles no light, but when I stopped the engine and restarted it the light came on again with the 2 faults. Looks like I need to clean the EGR valve to see if the cures it. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted November 30, 2021 Author Report Share Posted November 30, 2021 (edited) Bought and fitted the EGR valve and the problem has gone away, but still throws up the o2 sensor, can anyone tell me if the front exhaust sensor is the same as the downstream o2 sensor?? Edited November 30, 2021 by Shane56 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 30, 2021 Report Share Posted November 30, 2021 Try leaving it for the mo. They're pretty tough sensors. Once you've taken it for a motorway run, chances are it'll be good again. Just needs a decent clean out. Quote Link to comment Share on other sites More sharing options...
Shane56 Posted November 30, 2021 Author Report Share Posted November 30, 2021 Cheers MK2 I have changed the air filter, I'm doing the oil and plugs as well as the oil filter tomorrow. Quote Link to comment Share on other sites More sharing options...
