Lupo_Gti_Kor Posted March 17, 2021 Report Share Posted March 17, 2021 Recently, I removed the pedal to change the clutch master cylinder, but it was smashed to see if the clutch pedal return spring was worn out. So I found a similar shape on eBay and ordered it.The length is different, so it doesn't fit at all. I can't find the parts.Where can I get a shorter spring? I don't think Lupo has good maintenance. I have to wait two weeks if I order here in Korea, but I haven't been able to drive for four weeks already. left is new one, right is broken old one... Quote Link to comment Share on other sites More sharing options...
Rich Posted March 17, 2021 Report Share Posted March 17, 2021 Drive it anyway. It isn't a return spring, it's actually to make the clutch easier to press Quote Link to comment Share on other sites More sharing options...
LR5V Posted March 17, 2021 Report Share Posted March 17, 2021 Has the plastic part come unclipped from the metal base? - Seem to recall a similar problem when I was having my clutch saga. With cable ties you can crush the spring down small enough to clip the plastic back in and re-assemble: Once its back in place behind the pedal - cut the cable ties off Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 17, 2021 Author Report Share Posted March 17, 2021 4 minutes ago, LR5V said: Has the plastic part come unclipped from the metal base? - Seem to recall a similar problem when I was having my clutch saga. With cable ties you can crush the spring down small enough to clip the plastic back in and re-assemble: Once its back in place behind the pedal - cut the cable ties off Thanks mate. I also used a cable tie to compress it. But, the new one is longer than the previous one, so it's too long to compress it. I think I need to buy a new suitable part, where can I get it? Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 17, 2021 Author Report Share Posted March 17, 2021 1 hour ago, Rich said: Drive it anyway. It isn't a return spring, it's actually to make the clutch easier to press Even if i compress it, it's too long to fit between the pedals. Quote Link to comment Share on other sites More sharing options...
LR5V Posted March 17, 2021 Report Share Posted March 17, 2021 unless I am missing something - the old spring looks ok just assemble the old stuff Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 17, 2021 Author Report Share Posted March 17, 2021 3 minutes ago, LR5V said: unless I am missing something - the old spring looks ok just assemble the old stuff As I removed the clutch pedal, the existing parts broke like exploding. Even if I combine the new parts, the compressed length is too long to fit through the pedals. Does anyone know where I can buy the exact parts? Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 17, 2021 Author Report Share Posted March 17, 2021 The circled part is about twice as long as the previous one. So I took it apart and combined it with the existing parts, but it's not compressing well. I need an exact new product. Help me, please. Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 17, 2021 Author Report Share Posted March 17, 2021 comparison pic.. Quote Link to comment Share on other sites More sharing options...
Rich Posted March 17, 2021 Report Share Posted March 17, 2021 Picture when the spring is expanded. The pedal is pressed down. When returning the pedal actually compresses the spring. Maybe it's a damper for the way in which it shoots back? It wouldn't stop me driving it and I'd look towards Lupo TDI polo 6n2 TDI for a replacement. Like Orlando says, you have enough bits to rebuild something functional with what you have. Quote Link to comment Share on other sites More sharing options...
Lupo_Gti_Kor Posted March 18, 2021 Author Report Share Posted March 18, 2021 43 minutes ago, Rich said: Picture when the spring is expanded. The pedal is pressed down. When returning the pedal actually compresses the spring. Maybe it's a damper for the way in which it shoots back? It wouldn't stop me driving it and I'd look towards Lupo TDI polo 6n2 TDI for a replacement. Like Orlando says, you have enough bits to rebuild something functional with what you have. Thanks for your helps. but, As I said above, this is the combination of the old and the new. The old parts can't be used because the plastic broke while removing the pedal. The plastic length of the newly purchased part is longer even though it has been compressed enough with a cable tie. No matter how long I try to put the spring in the pedal box, it's not working because it's long. Again, please let me know if you know the right item number or place of purchase. There is no answer but to exchange this for a new one. help ㅠㅠ *pic: white plastic part and spring is old one and I combined the black part below into a new part and it's long. Quote Link to comment Share on other sites More sharing options...
LR5V Posted March 20, 2021 Report Share Posted March 20, 2021 Stop using the new parts! What is stopping re-assembling the old parts? Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 20, 2021 Report Share Posted March 20, 2021 Different to my SDI, but are we talking the clutch release bearing, slack take up spring? To stop the release bearing bouncing around on the clutch pressure springs? Quote Link to comment Share on other sites More sharing options...
