thejettasetta Posted July 28, 2019 Report Share Posted July 28, 2019 Did a search to see if this has already been covered, could I also ask members expertise please? My 2001 Lupo GTi 5 speed has an issue getting into 3rd gear. At higher revs it can crunch into 3rd, or not go in at first, it just kind of rattles around before being placed into gear. This has got worse slowly. At lower revs it is better. The problem only affects 3rd gear. It had a clutch @ 105k & is currently on 120k. Does this sound like a synchro issue? Is it an expensive fix or is that hard to tell without getting it looked at properly? I'd appreciate any advice & apologies if this has been covered many times before. Cheers Quote Link to comment Share on other sites More sharing options...
Mattymdm Posted July 28, 2019 Report Share Posted July 28, 2019 Sounds like a synchro issue. Take the box out yourself and someone will be able to refurbish it for you. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 28, 2019 Report Share Posted July 28, 2019 I've replaced third before and it was a minefield to get corresponding rings and everything due to superceded parts. Make sure it goes somewhere who knows these things Quote Link to comment Share on other sites More sharing options...
thejettasetta Posted July 28, 2019 Author Report Share Posted July 28, 2019 Thank you for the replies; much appreciated. Are we talking several hundreds to put right? Quote Link to comment Share on other sites More sharing options...
LR5V Posted July 28, 2019 Report Share Posted July 28, 2019 Price varies for rebuilds, I would say it will be 2 to 3 hundred for the rebuild. More if whoever does the work has to take the box out - you can get a gauge on what that cost will be from the labour doing the clutch. Unless you know otherwise, chances are the oil in the box is from factory - I would be tempted to try renewing the gearbox oil, it wont fix it but may smooth it out and keep you on the road a bit longer. Failing that, get old school and practice double de-clutching! Quote Link to comment Share on other sites More sharing options...
thejettasetta Posted July 28, 2019 Author Report Share Posted July 28, 2019 Thank you all, much appreciated Quote Link to comment Share on other sites More sharing options...
