Lupospain
Hi! Arosa & Gti from Spain
Hello! I'm Alvaro, from Huelva, Spain. I present my Seat Arosa 1.0 AHT year 1999 to 1.4 16v AFH (90k miles) and my Lupo Gti year 2001 (78k miles).
Take this opportunity to ask about the installation of cruise control at GTi. Does anyone have the wire scheme? Has anyone made him run in Lupo GTI?
Thank you!
Photos:
Photos:
Lupo GTi ECU doesn't like the cruise control option.
Hey hey! Que bien! Bienvenido a club lupo. :)
yeah but @Rich isn't there a built in routine in some of the lupo ecus? You can use the switch gear from a T4 i think? Never done the mod.
I've never tried it so I could be completely wrong, would the Polo GTi ECU work or is the wiring too different?  Always pondered but never fully looked into it.
I've ran Lupo avy using Polo GTi ECU so I wouldn't think that was an issue....
Six speed 6n2 ftw.
  • Thanks 1
I bought the tempomat of t4 and I'm going to try it. I read in some forums, it works, and in others it does not work.
I have 2 diagrams:
1st:
Pin 1 (White) --> 68 ECU
Pin 2 (Blue) --> 67 ECU
Pin 3 (Red) -->66 ECU
Pin 4 (Negro) --> 69 ECU +12v
2nd:
Pin 1 (White) --> 68+69
Pin 2 (Blue) --> 67
Pin (Red) --> 66
Pin (Black) --> +12v
Vagcom: Engine/Login 11463
Ok, let us know if it works... :)
Yeah this thing...
https://www.ebay.co.uk/itm/NEW-GENUINE-VOLKSWAGEN-T4-TRANSPORTER-CRUISE-CONTROL-RETROFIT-KIT-TDI-7D0998527-/201955850138
steering wheel off, remove clock spring. Add T4 cruise stalk. Refit everything. Sorted. I don't even think you need to reprogram the ECU. It's already built in, ready to go. Just waiting for the turn cruise on. 'Set'......
  • Thanks 1
I'm waiting for shipment of the part. As soon as receive it, I will install it and connect to ECU.
I will inform you if it works in Lupo Gti or not.
If it works, I will do a "how to do it". If it doesn't work, i will cry 😭🤣
Hello! I am in the cruise control assembly (Tempomat). I have varnished the piece with a matt spray so that the white letters are not erased due to the use. I have already put the cable that goes to the ECU but I have not plugged it yet. First I will dismantle the steering wheel and place the tail. I attach images where I have passed the cables that connect in the ECU.
Very nice.
I look forward to it.
Hello again! I am sorry I did not upload photos, it is difficult to upload them but I keep trying. Today I connected everything, activated with VAGCOM and it doesn't work. I don't know whether to change the ECU to that of a Polo 6n2 or try another combination of cables. If I make it work, I'll let you know. :(
Edited by Lupospain
No :( (on my ipad)
Edited by mk2
