JayGee Posted April 20, 2018 Report Share Posted April 20, 2018 Hi, Looking for some help please, I have a 2003 Seat Arosa Sport 1.4 16v, The pedal box issue has happened and needs replaced, Would anyone be able to tell me where to get the parts as the part numbers given in a how to fix it post doesn’t show anything when searching online, Parts have been advised need to order are: 1 pedal box (part number S6X2721115G), 1 brake pedal clip (part number 1H2721169), 2x M8x20mm sheer bolts (part number SN90583001) Can anyone confirm these are still the correct parts numbers to get, and where to get them? Cheers, john Quote Link to comment Share on other sites More sharing options...
Rich Posted April 20, 2018 Report Share Posted April 20, 2018 don't bother replacing the shear bolts with shear bolts. go to tps, Google it. Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 20, 2018 Author Report Share Posted April 20, 2018 Cheers, When I go to tps and type in the part no's from above nothing is found, Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 21, 2018 Report Share Posted April 21, 2018 11 hours ago, Rich said: don't bother replacing the shear bolts with shear bolts. go to tps, Google it. TPS is just Vdub in disguise (it's owned by VAG). I've found pricing identical to dealers... Quote Link to comment Share on other sites More sharing options...
JoeyEunos Posted April 21, 2018 Report Share Posted April 21, 2018 3 hours ago, mk2 said: TPS is just Vdub in disguise (it's owned by VAG). I've found pricing identical to dealers... Weird, I've found them a fair bit cheaper... 5l of Quantum Platinum is circa £12 at TPS but close to £30 at the dealer, '5+ range' battery for the Golf was £55 at TPS but £70ish at VW Also the red Quantum coolant they sell meets G12 and is cheap, unlike the extortionate purple G13 stuff at the stealer Maybe there are regional differences? Either way (And back on topic) I'm pretty sure @Rich offers a drive in-drive out pedal box welding service, depending on where you are it might be worth giving him a nudge Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 21, 2018 Author Report Share Posted April 21, 2018 Had thought about it but I'm in Central Scotland, Can anyone advise where to get the pedal box parts as can't find them on the TPS website, cheers Quote Link to comment Share on other sites More sharing options...
Rich Posted April 21, 2018 Report Share Posted April 21, 2018 i just change them out for pre welded ones. 40 minute job that ... Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 21, 2018 Author Report Share Posted April 21, 2018 @Rich Would you be able to advise what I would need to strip from the car before coming down from Central Scotland to Durham for you to do this, cheers, Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 21, 2018 Report Share Posted April 21, 2018 i only recently chucked one of my broken ones- i could have sent it to you as another to be welded. shame. dont ecp still sell them for about £20? Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 21, 2018 Author Report Share Posted April 21, 2018 Cheers, So if I get the pedal box out can it be welded so doesn't happen again as other posts I have seen say it just happens again unless you get a new updated pedal box, Just checked ECP and nothing coming up, Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 21, 2018 Report Share Posted April 21, 2018 anything can be welded. add more steel sheet if you want to make it completely indestructable.... Quote Link to comment Share on other sites More sharing options...
Rich Posted April 21, 2018 Report Share Posted April 21, 2018 clutch ages, gets heavy, spot welded bracket for clutch shears and gives out. if you repair the original you must reset it so that it is as it was before it bent. you wouldn't have to remove anything. 1 Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 23, 2018 Author Report Share Posted April 23, 2018 (edited) Would anyone be able to confirm I have the correct part numbers for what is needed as I contacted a Seat dealer today and their parts department said they can't find anything and I need them asap as the car won't go into reverse now, Cheers, Part Numbers: pedal box: S6X2721115G brake pedal clip: 1H2721169 sheer bolts: SN90583001, may not bother with these but would like the option if possible, Edited April 23, 2018 by JayGee Quote Link to comment Share on other sites More sharing options...
JayGee Posted April 23, 2018 Author Report Share Posted April 23, 2018 (edited) Just to check in this diagram is it the highlighted part, number 1 that I've to get, cheers Edited April 23, 2018 by JayGee Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 24, 2018 Report Share Posted April 24, 2018 that's a great diagram... where's it from? 1 Quote Link to comment Share on other sites More sharing options...
cj1 Posted April 24, 2018 Report Share Posted April 24, 2018 (edited) Not to be cynical but I don't understand why people obsess over having their own part numbers before ringing a dealer. Could solve the problem in half of the time. It's what they're there for, if they can't find the pedal box on their diagrams i'd be worried! Also IIRC the brake pedal clip isn't available on it's own from VAG specifically for the lupo. Mk3 golf one. Edited April 24, 2018 by cj1 Quote Link to comment Share on other sites More sharing options...
Rich Posted April 24, 2018 Report Share Posted April 24, 2018 I have put a lot of these together without the clip. Quote Link to comment Share on other sites More sharing options...
JT76 Posted January 14, 2021 Report Share Posted January 14, 2021 Hi, I found this thread and I have the same issue. The clutch pedal on my 2002’Arosa has broken. @Rich did I read your in Durham? I’m in Newcastle. My brother (mechanic) welder it but it lasted a month. Could you let me know if you still off a drive in drive out welding service still? If so please contact me on 07519655659 Thanks J Quote Link to comment Share on other sites More sharing options...
