Jomer Posted February 17, 2017 Report Share Posted February 17, 2017 (edited) Hello Friends i have a huge problem with my CD Kenwood KDC-3057UR i put my stick USB and written me NA Device. if someone had such a problem and it allowed please share Thanks ! Edited February 17, 2017 by Jomer Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 18, 2017 Report Share Posted February 18, 2017 Perhaps it doesn't support the type of music file you are using? Or it can't find the directory they are stored in? Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted February 18, 2017 Report Share Posted February 18, 2017 not all usb devices are supported http://www.kenwood.com/jp/usb/english.html Quote Link to comment Share on other sites More sharing options...
Jomer Posted February 18, 2017 Author Report Share Posted February 18, 2017 my usb its 4GB sandisk 4gb cruzer blade is formatted FAT32.. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 23, 2017 Report Share Posted February 23, 2017 My bet is that it needs a Low Level format, but there we go. Quote Link to comment Share on other sites More sharing options...
stathis Posted June 27, 2018 Report Share Posted June 27, 2018 The same problem I have. Can you help me ? 1 Quote Link to comment Share on other sites More sharing options...
soheil Posted September 3, 2018 Report Share Posted September 3, 2018 hi! In the Start menu, type cmd, and then click the entry for the cmd program. At the command prompt, enter diskpart (you might have to approve this operation as an administrator). The prompt line should now display "DISKPART". Enter list disk. Enter select disk X, where X is the number of your selected disk. Enter clean. Enter create partition primary. Enter select partition 1. Enter active. Enter format fs=fat32. Enter assign. Enter exit. Quote Link to comment Share on other sites More sharing options...
soheil Posted September 3, 2018 Report Share Posted September 3, 2018 On 6/27/2018 at 10:14 AM, stathis said: The same problem I have. Can you help me ? In the Start menu, type cmd, and then click the entry for the cmd program. At the command prompt, enter diskpart (you might have to approve this operation as an administrator). The prompt line should now display "DISKPART". Enter list disk. Enter select disk X, where X is the number of your selected disk. Enter clean. Enter create partition primary. Enter select partition 1. Enter active. Enter format fs=fat32. Enter assign. Enter exit. Quote Link to comment Share on other sites More sharing options...
Skezza Posted November 20, 2018 Report Share Posted November 20, 2018 On 9/3/2018 at 3:15 PM, soheil said: hi! In the Start menu, type cmd, and then click the entry for the cmd program. At the command prompt, enter diskpart (you might have to approve this operation as an administrator). The prompt line should now display "DISKPART". Enter list disk. Enter select disk X, where X is the number of your selected disk. Enter clean. Enter create partition primary. Enter select partition 1. Enter active. Enter format fs=fat32. Enter assign. Enter exit. So basically a low level format. Thought so.... but anyway. Quote Link to comment Share on other sites More sharing options...
Jonah Hickman Posted September 1, 2019 Report Share Posted September 1, 2019 I know this is an old forum, but I kept having the cmd diskpart fail after every attempt (took hours). I finally was able to fix my usb drive so that it could work by downloading https://www.disk-partition.com/download-home.html and following this guide I found https://www.disk-partition.com/diskpart/vitual-disk-service-error-the-volume-size-is-too-big.html . Apparently Windows can't do jack to the drive if it exceeds 32 gb. Hope it helps someone! Quote Link to comment Share on other sites More sharing options...
doncelis Posted April 27, 2020 Report Share Posted April 27, 2020 (edited) You need format usb from gpt to mbr. 1. Put ur USB to PC 2. Open CMD with administrator 3. diskpart 4. list disk 5. select disk X (X= number disk) 6. convert mbr 7. exit 8. exit You must have usb 2.0 and format usb to fat32 Edited April 27, 2020 by doncelis Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 28, 2020 Report Share Posted April 28, 2020 On 11/20/2018 at 4:48 PM, Skezza said: So basically a low level format. Thought so.... but anyway. That's a partition function. low level format assigns which cells are bad in a flash memory (factory process step usually), same as on a hard disk drive. Similar sort of concept though You used to be able to get the manufacturers' low level format app functions until the chinese realised that they could start 'reformatting' smaller flash cards to make them look bigger to a file system program. Then people wondered why their flash memory just started to behave wierdly, or lost data. Always buy a known brand from an authorised reseller. So many many many fake flash memory cards out there! Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 30, 2020 Report Share Posted April 30, 2020 On 4/28/2020 at 7:09 PM, mk2 said: That's a partition function. low level format assigns which cells are bad in a flash memory (factory process step usually), same as on a hard disk drive. Similar sort of concept though You used to be able to get the manufacturers' low level format app functions until the chinese realised that they could start 'reformatting' smaller flash cards to make them look bigger to a file system program. Then people wondered why their flash memory just started to behave wierdly, or lost data. Always buy a known brand from an authorised reseller. So many many many fake flash memory cards out there! I lazily conflate rebuilding partitions with a low level partition. I know the historical significance of low level formats on spinning disks although I don't think we do them anymore. Quote Link to comment Share on other sites More sharing options...
MrBoylan Posted August 13, 2020 Report Share Posted August 13, 2020 Formatting the USB thumb drive as Fat32 (instead of NTFS or exFat), solved the problem for me. Just right click on the drive in Windows and select the "Format" option and format as Fat32. Formatting will wipe out anything on the drive so you will have to copy the music onto the drive after doing the format. Quote Link to comment Share on other sites More sharing options...
MrBoylan Posted August 13, 2020 Report Share Posted August 13, 2020 On 7/7/2020 at 3:18 AM, Aji Potter said: so what was the problem ? why there was this issue ? For me, with the same error, I had tried using a thumb drive that was formatted incorrectly. Once I formatted the thumb drive as Fat32, it worked great. Quote Link to comment Share on other sites More sharing options...
