Ryan5257 Posted February 4, 2017 Report Share Posted February 4, 2017 Recently brought my vw Lupo as a first car and had to do loads of work on it so far, my most recent problem is that it's running to rich still? It had a decat and didn't have no lamba sensors or anything like that so was drinking petrol I recently put a cat on it and brought all the sensors and fitted a new exhaust system and it's still running a little rich, I plugged in the dionostics kit and it says rich tread bank 1 sensor 1 any ideas? Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 4, 2017 Report Share Posted February 4, 2017 "Rich tread bank 1" huh? Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 5, 2017 Author Report Share Posted February 5, 2017 Literally all it says when I plug it in it just says rich thread bank 1 sensor 1, I didn't know what I meant that's why I asked on here, Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 5, 2017 Report Share Posted February 5, 2017 I dont think it'll mean anything to anyone on here... But i could be wrong! "Thread" "bank"?!?! Its not a "V" engine. And as for thread.... Anyone know much about sewing machine motors? Ah, no, that's the Daihatsu forum.... Quote Link to comment Share on other sites More sharing options...
mattarosa Posted February 5, 2017 Report Share Posted February 5, 2017 Type the code into google that'll help. Quote Link to comment Share on other sites More sharing options...
mattarosa Posted February 5, 2017 Report Share Posted February 5, 2017 (edited) https://www.obd-codes.com/trouble_codes/volkswagen/ http://wiki.ross-tech.com/wiki/index.php/00915 Edited February 5, 2017 by mattarosa Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 5, 2017 Author Report Share Posted February 5, 2017 Okay Matt thank you:) Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted February 5, 2017 Report Share Posted February 5, 2017 have you tried disconnecting the battery to reset the ECU, if its gone from not having a lamba sensor to then having one it may need to relearn and make adjustments as this sensor checks the oxygen in the exhaust system which is a really good guide to whats happening with the combustion process Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 6, 2017 Author Report Share Posted February 6, 2017 I will try that for sure great idea thank you:) Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 7, 2017 Report Share Posted February 7, 2017 Have you managed to make any sense of the error codes? Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 8, 2017 Author Report Share Posted February 8, 2017 Yeah it's this - P0135 is the OBD-II generic code indicating the engine control module (ECM) has tested the O2 sensor heater circuit and has detected a problem with the bank 1 sensor 1 O2 sensor heater circuit. O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1) Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 8, 2017 Author Report Share Posted February 8, 2017 Basically it's my sensors what knackered then, Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 8, 2017 Report Share Posted February 8, 2017 For what its worth, Bank 1 Lambda sensor is pre-cat and Bank 2 is after the cat Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted February 14, 2017 Report Share Posted February 14, 2017 has this been fixed yet, if so what was the cure Quote Link to comment Share on other sites More sharing options...
lupo 1.7sdi Posted February 15, 2017 Report Share Posted February 15, 2017 Bank 1, Sensor 1 = pre-cat Bank 1, Sensor 2 = after-cat Bank 2 is for longitudinal engine with two exhaust manifold. https://static.cargurus.com/images/site/2015/03/24/19/52/pic-3585884633758656484-1600x1200.jpeg Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 15, 2017 Author Report Share Posted February 15, 2017 Should I have two sensors or should I only have one? Because I thought that I should have to I should have a pre cat and then one for my cat? I haven't got round to solving it yet but will be changing the sensor when I've got spare time, Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 15, 2017 Author Report Share Posted February 15, 2017 Because it's sensor one the cure should Be just to replace my pre cat sensor then really shouldn't it? Quote Link to comment Share on other sites More sharing options...
mattarosa Posted February 15, 2017 Report Share Posted February 15, 2017 Yes the cure is replace your pre cat lambda sensor, they breakdown inside overtime and can be finished off by a sudden jolt, ie pothole, mine went just before an mot, the dealers said try running it and if that doesn't work replace. You may also have seen a decrease in fuel economy. Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted February 15, 2017 Report Share Posted February 15, 2017 I don't know what the connections are like but if possible have you tried swapping the sensors to see if the problem moves, if its possible and the problem moves its a safe bet its the sensor, if it doesn't then its more likely the wiring Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 15, 2017 Author Report Share Posted February 15, 2017 I'll try that first thing tomorrow I'll swap the sensors over and see if that fixes it:) Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 17, 2017 Author Report Share Posted February 17, 2017 Took the sensor off today and waiting for a new one to arrive so I can fit it, this is the state of the old one, Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 18, 2017 Report Share Posted February 18, 2017 That's black... Should be a pale brown colour (like spark plugs). Running rich... Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 18, 2017 Author Report Share Posted February 18, 2017 Yeah that's the reason I'm changing it, had a decat on before, Quote Link to comment Share on other sites More sharing options...
Ryan5257 Posted February 22, 2017 Author Report Share Posted February 22, 2017 Changed it today it isn't running as rich trying clearing the code and it won't clear it keeps coming back on? Ideas? Quote Link to comment Share on other sites More sharing options...
