patroddy Posted January 8, 2016 Report Share Posted January 8, 2016 Hi guys I've got a battery drain on my lupo gti. Its taking about 2 days to go to a point where there isn't even enough power to operate the central locking or anything. This is also a brand new battery. Its got an aftermarket H/U (i have switched the live wires so they work correctly) it also has V2 airride fitted with my switch on cable coming from my interior fusebox, the airride doesn't turn on until the ignition is on so i doubt it is that I've also unplugged the manifold and its still gone dead. i don't know how long this problem has been happening as everyday I've owned the car its driven 70 miles to work and back apart from very recently where I've stopped using it daily so i can't even put it down to a time or modification. I'm going to get my ammeter on it and start pulling fusses and seeing what I find but id like some ideas of where to start looking first from anyone who's had this problem before. Cheers Pat Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 8, 2016 Report Share Posted January 8, 2016 Pulling fuses out of external bits and bobs (your air ride etc) might be a good shout. Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted January 8, 2016 Report Share Posted January 8, 2016 Your looking for 1 to 1.5 amps to flatten a battery in 2 days, Is your ignition switch really off ? check the back of the switch, if it is then it's stuff which runs anyway that you need to check. Radio, Central locking, alarm, engine cooling fan come to mind. There may be more, you need to look at the wiring diagram to see what directly feeds from the battery. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 8, 2016 Report Share Posted January 8, 2016 5 hours ago, carrera-gt said: Your looking for 1 to 1.5 amps to flatten a battery in 2 days, Is your ignition switch really off ? check the back of the switch, if it is then it's stuff which runs anyway that you need to check. Radio, Central locking, alarm, engine cooling fan come to mind. There may be more, you need to look at the wiring diagram to see what directly feeds from the battery. You'll hear the fan and the radio wouldn't switch off. Central locking would only drain if the solenoid was repeatedly firing. Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted January 9, 2016 Report Share Posted January 9, 2016 10 hours ago, Skezza said: You'll hear the fan and the radio wouldn't switch off. Central locking would only drain if the solenoid was repeatedly firing. Or perhaps the solenoid is staying energised ? Quote Link to comment Share on other sites More sharing options...
Sausage Posted January 9, 2016 Report Share Posted January 9, 2016 http://www.wikihow.com/Find-a-Parasitic-Battery-Drain Quote Link to comment Share on other sites More sharing options...
patroddy Posted January 9, 2016 Author Report Share Posted January 9, 2016 cheers i know how to find one i was just wondering if their were any common ones people have come across thanks for all the help! Quote Link to comment Share on other sites More sharing options...
patroddy Posted April 23, 2016 Author Report Share Posted April 23, 2016 bringing this back from the dead, i tried to do a battery drain test and found noting unfortunately but the car still drained however this morning i ran the car through vagcom to find an ABS issue and got this coding up (see below) does anyone know how to fix this bad boy? Quote Address 35: Centr. Locks Labels: 1C0-962-258-III.lbl Part No: 1C0 962 258 AB Component: 16 Zentr.Verriegel. 0003 Coding: 00016 Shop #: WSC 01233 VCID: 67D7A5450576F51 2 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 01135 - Interior Monitoring Sensors 36-10 - Open Circuit - Intermittent i assume the first fault was from when the battery went dead the second is what i think is causing the fault - how do i fix this Quote Link to comment Share on other sites More sharing options...
K70SLY Posted April 14, 2023 Report Share Posted April 14, 2023 Hi mate, Did you manage to sort this in the end? I am currently having a very similar issue where my battery is draining but i cannot find the drain at all... my battery is new and is pulling 0.1amps as normal but the car will fully drain after about 12-24 hours Hoping to find a fix from someone else's issues potentially, any ideas for mine? Cheers. Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 15, 2023 Report Share Posted April 15, 2023 100 mA is a lot. 5-10mA is normal. Check the alternator. Two of my Lupos have had this problem. One of the diodes inside the alternator became "leaky" allowing power to drain back into it. Disconnect the alternator power out cable at the battery junction (or alternator), and remeasure the power drain. The other way is to disconnect every fuse, one at a time, until you find it. Measure each time. Let us know if you find it! Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 15, 2023 Report Share Posted April 15, 2023 That sounds like the kind of energy a radio might pull if it was wired up wrong. Quote Link to comment Share on other sites More sharing options...
