James_VW Posted January 28, 2015 Report Share Posted January 28, 2015 What's best to replace the foam sheet that is on the door behind the door cards?Thanks in advanced Quote Link to comment Share on other sites More sharing options...
mattarosa Posted January 30, 2015 Report Share Posted January 30, 2015 A new one from the stealers is the best but hey, floor underlay seems to be a similar stuff.laminate underlay that is, not carpet. Quote Link to comment Share on other sites More sharing options...
BlackArosa Posted February 8, 2015 Report Share Posted February 8, 2015 use some wood haha Quote Link to comment Share on other sites More sharing options...
RichNor Posted February 23, 2015 Report Share Posted February 23, 2015 (edited) polyethylene sheet, the heavy duty kind and waterproof doublesided tape? Thats what i used for my scirocco, did the trick. Also seen people using duct-tape, if you're into that Edited February 23, 2015 by RichNor Quote Link to comment Share on other sites More sharing options...
James_VW Posted February 24, 2015 Author Report Share Posted February 24, 2015 Might look into using that actually Currently I have actually just used tape for a temporary job But I did contact the stealership and found prices...upper pieces around £10 eachlower pieces around £15 each Quote Link to comment Share on other sites More sharing options...
RichNor Posted February 24, 2015 Report Share Posted February 24, 2015 You can also use a heat gun to shrink the plastic sheeting a little after mounting, for a nice, tight look. There is a thing even better that tape as well, dont know the name, but it is what is used on older VW's to hold membrane in place, black sticky stuff, comes in a roll, after fitting to the plastic, you can take the sheet of and on with out replacing the stuff. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 25, 2015 Report Share Posted February 25, 2015 Radiator insulation is very similar. Also butyl flashing tape. Plus, with the flashing tape you can do some extra dampening. Quote Link to comment Share on other sites More sharing options...
Reedo Posted February 25, 2015 Report Share Posted February 25, 2015 could you not use sound deadening? Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 25, 2015 Report Share Posted February 25, 2015 could you not use sound deadening? basically butyl flashing tape Quote Link to comment Share on other sites More sharing options...
Reedo Posted February 27, 2015 Report Share Posted February 27, 2015 im glad someone has done this thread because mine are missing on all four sections so gunna do that hopefully ok cheers skezza Quote Link to comment Share on other sites More sharing options...
