FullFlex
PD100 gearbox straight swap for a lupo tdi?
Hi all,
my lupo gearbox is dying and i'm planning to put a gt1749va decat and remap,
i read somewhere that pd100 gearbox is plug and play on a lupo 1.4 tdi...
can someone comfirm that? and if yes what flywheel and clutch do i need?
not sure if it's clear :)
thanks
no.
Why do you think the box is on its way out ?
it won't shift down between 3rd ans 2th, or at low low rpm, i know it's a synchro spring, it can be rebuilt
but as i'm planning to put a 1749 turbo, if i can change for a better gearbox it's better.
i think the pd100 gearbox have longer gears and are stronger.
some people said me it's a straight swap from ibiza, polo or fabia pd100,
but i have to change the flywheel and clutch for a G60 flywheel and Golf tdi clutch...
i'm not sure of nothing so i ask here, i just want to put a bigger turbo gearbox and breaks to my tdi
Ok i understand it's another gearbox thread... so i'm buying an ibiza pd100 gearbox
i will use a G60 flywheel, and pd 100 clutch... i try that and i will see
i maybe need the shifter too.
i already have
a gt1749va turbo modified to fit on the 1.4tdi manifold
girling G60 callipers
polo rear disc beam
joms :)
project on it's way...
edited into
Edited by Keelan
love how this literally went from
"will it fit"
"no"
"I've bought it and it will fit"
I forgot if the boxes are o2j or o2a
I have no idea how mounting the to the engine change between them.
Are you going to get the standard 10k the lightened 7k
I was wondering if this was possible so I'm definitely going to see how can gods.. I hope for loads of pictures, part numbers and descriptions.
How do you know the measurements of the flywheel bolt sizes and Placement. Does thejob clutch hydraulic feed need changing
Yep,you are right... i'm going the noob way...,
and in fact i'm so bad at english that it's hard for me to explain all those things.
i'm not a mechanics, i work for me with no help so i do what i can.
it starts with my brothers polo... i take it to go shopping, and i fall in love...
1 week later a bought a tdi lupo with a 1.9 tdi conversion in mind...for fun
the fact is in france, swaps are not possible. french mot... insurances...
so i decided to boost the 1.4 and so i start reading all i can find on the subject.
after many research i find that i can put a vnt turbo etc... but also that the gearbox will die quick.
so after many readings on vw gearbox... pretty simple subject... i read nils6L post on his arosa...
and try to copy his setup, but i don't really want to open my gearbox rebuild it, and broke it because it's a weak gearbox
and i want torque :)
after discussions with a french friend who own a 175bhp Ibiza 1.4tdi, i conclude that pd100 ggu gearbox will fit
with another flywheel and clutch.... i came here to get answers on the compatibility...
as i can't have any , i go my way :)
in fact i found an ibiza GGU gearbox 30k miles approx, for 200£... so i bought it anyway
i'll order that soon also
http://www.darksidedevelopments.co.uk/products/darkside-silent-g60-single-mass-flywheel-clutch-kit-for-5-speed-02j-02a-02r.html
i have a gt1749va out of a passat 130 modified to fit the amf manifold
a 320d intercooler
now a GGU gearbox so a 02R :)
and some G60 callipers
mini_45448110947676101530229475392461603
and a rear disc beam from a polo 6n tdi
and... i must find a 23,8 mm master cylinder...
i need also to remap, but i find someone who can do it and test it on the roller to...
so i need advices... Thanks :)
Edited by FullFlex
I am not the man to give advice.
Do you know if the gearbox will match up to the blocks mounting holes
same bolt pattern, same housing, i may need another shifter i dont know
gears are longer and should match with remap, i will see,
Edited by FullFlex
