colinsimons Posted November 20, 2014 Report Share Posted November 20, 2014 I have a Touran 55 Reg.(2005)i'm having sporadic problems with the interior heater system.most often it will not get hot enough but sometimes it does.i have already had the coolant thermostat changed which might have made some difference but the heat out of the heater is not good enough most of the time! Quote Link to comment Share on other sites More sharing options...
Pete Posted November 20, 2014 Report Share Posted November 20, 2014 Are you gonna be ok?? 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted November 20, 2014 Report Share Posted November 20, 2014 You need to assertain which aspect you're unhappy with.Is the fan working at all the different speeds?Is it that you're just unhappy with the heat coming from the fans?Is it possible that the car has suffered from a blown heater matrix and someone has bypassed it within the bay and you haven't noticed until now ? Quote Link to comment Share on other sites More sharing options...
colinsimons Posted November 21, 2014 Author Report Share Posted November 21, 2014 Thanks for the infoThe fan is working perfectly on all speeds.The heat from the fans, when set to max is mostly not very hot but is sometimes quite hot.had the car from new so no one has meddled with the system beforethanks Colin Quote Link to comment Share on other sites More sharing options...
Silver! Posted November 21, 2014 Report Share Posted November 21, 2014 Excuse Pete.He is the forum retard. It's not often he get's out of the care home or allowed unsupervised access to the internet, but when he does, well we just accept him for what he is.Love you Pete.Bry; get him back in his cell room! Quote Link to comment Share on other sites More sharing options...
Skezza Posted November 21, 2014 Report Share Posted November 21, 2014 (edited) Grill blocking.Ghetto as **** but it works so well!! I'll be doing some nearer January when it gets mighty cold. Edited November 21, 2014 by Skezza Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 21, 2014 Report Share Posted November 21, 2014 Possibility it wasn't bled properly? Get vagcom and see what temp it's getting foo. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 21, 2014 Report Share Posted November 21, 2014 If it heats up well on a run intermittently then surely it could be a water pump issue? You've had it from new, not noticed any leaks before or during the issue. So a component failure must surely be possible.And love you too Rayray, that's the nicest thing you've ever said about me. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 21, 2014 Report Share Posted November 21, 2014 Grill blocking. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 22, 2014 Report Share Posted November 22, 2014 Grill blocking.Ghetto as **** but it works so well!! I'll be doing some nearer January when it gets mighty cold.I don't know how cold it is there but it's about 9c here I'm still on grill block already. Round town it's about 86c driving slowly. 89c on the dualer. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted November 22, 2014 Report Share Posted November 22, 2014 Has it got climatronic? Could have a broken temperature sensor or heater flap motor. Quote Link to comment Share on other sites More sharing options...
