Rickpercy87 Posted October 10, 2013 Report Share Posted October 10, 2013 I have noticed today when I put my foot down my turbo is kicking in more slower than usual, and maybe a bit later aswell. Just after 2k. I am due a service. Any easy vacuum leak tests. Surely I should have a fault code... Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 10, 2013 Report Share Posted October 10, 2013 Checked oil level and coolant level? Should be spooling at 1500 and getting good boost at 1.8krpm. EGR dirty? Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 11, 2013 Report Share Posted October 11, 2013 Faulty maf may be. Quote Link to comment Share on other sites More sharing options...
Rickpercy87 Posted October 13, 2013 Author Report Share Posted October 13, 2013 I'll be checking my MAF in a few hours and blanking my EGR if I can find the plate I bought a while ago. OIl and coolant are spot on. I noticed it hesitate the other day as I accelerated onto the motorway. Engine was quite cold and stuttered for a split second around 3k RPM (like it missed misfired but just once). I usually take it easy until its warmed up so i'm not sure if that has anything to do with it. Iv'e done alot of searching since I posted this and i'm beginning to think its MAF, EGR or injector related. I thought about the glow plugs, but don't they only work when you turn the ignition? or do they stay hot until the engine is ar 90 degrees or something? Quote Link to comment Share on other sites More sharing options...
danoid Posted October 14, 2013 Report Share Posted October 14, 2013 Why do people blank the EGR There is a fault that needs to be fixed not bodged Quote Link to comment Share on other sites More sharing options...
Skezza Posted October 14, 2013 Report Share Posted October 14, 2013 Why do people blank the EGR There is a fault that needs to be fixed not bodged I've always been told you shouldn't blank your EGR as it can cause your engine to overheat??? Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 15, 2013 Report Share Posted October 15, 2013 I've always been told you shouldn't blank your EGR as it can cause your engine to overheat???Lol!!! Who told you that? Some people say well you need the egr to mix in so there is less oxygen in the cylinder so less bang and heat. They are silly silly people IMO. All it does it gunk up sludge and grime up the engine. Reduce performance add heat and used air and it's something that can break. No thanks. I've been blanking them off for years on many diesels had no problem once on a diesel. Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 15, 2013 Report Share Posted October 15, 2013 Why do people blank the EGR There is a fault that needs to be fixed not bodged On a petrol I'd agree but not on a diesel. It's just silly to meet emissions which in turn reduces efficiency and life of the engine. Crazy. Quote Link to comment Share on other sites More sharing options...
Skezza Posted October 15, 2013 Report Share Posted October 15, 2013 Lol!!! Who told you that? Some people say well you need the egr to mix in so there is less oxygen in the cylinder so less bang and heat. They are silly silly people IMO. All it does it gunk up sludge and grime up the engine. Reduce performance add heat and used air and it's something that can break. No thanks. I've been blanking them off for years on many diesels had no problem once on a diesel. and it doesn't effect economy? Quote Link to comment Share on other sites More sharing options...
Rickpercy87 Posted October 15, 2013 Author Report Share Posted October 15, 2013 Well I didn't find the plate to blank my EGR and I came across a jubilee type clip which I couldn't remove for the MAF. Why my toolbox has no pliars is ridiculous! I ordered some BG244k to see if that helps. I'll keep you posted on that one. Should be arriving today. I did have a look at the EGR too, have any of you removed one from the 1.4Tdi? The bolts are in hard to reach places. I have no time to do it this week so I could do with some research on my dinner breaks.Regarding the EGR, I think I remember one or two accounts of blown cylinder heads which were blamed on blanked EGR's or deleted EGR's. Personally I can only see benefits except increased fuel consumption due to the engine heating slower than usual. But after it's warmed up fuel economy increases. Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 15, 2013 Report Share Posted October 15, 2013 and it doesn't effect economy?Yes it does. No egr = better economy. Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 15, 2013 Report Share Posted October 15, 2013 I put a blanking plate on my tdi, soon took it off as it was taking an age to warm up. And tbh my car had done 180k when I cleaned the mani and EGR out and it wasn't too bad and performance gains were minimal if atall so iv not put it back in.Next time you drive the car, unplug the maf, if it drives better there's a good chance it's that at fault. Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 15, 2013 Report Share Posted October 15, 2013 I put a blanking plate on my tdi, soon took it off as it was taking an age to warm up. And tbh my car had done 180k when I cleaned the mani and EGR out and it wasn't too bad and performance gains were minimal if atall so iv not put it back in.Next time you drive the car, unplug the maf, if it drives better there's a good chance it's that at fault.I've always found the opposite true. These diesels take ages to heat up anyway but it's always up to temp before the dual carriage way. Is your remapped? Did you look in the inlet manifold though? Quote Link to comment Share on other sites More sharing options...
Rickpercy87 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Car is driving sweet again. I have changed the fuel filter and ran it with some BG244K for about 20 miles. No hiccups. Hope it still runs fine after this tank is empty. Quote Link to comment Share on other sites More sharing options...
Rickpercy87 Posted November 19, 2013 Author Report Share Posted November 19, 2013 Just an update. I have noticed a fuel leak from the fuel filter. I think the original clips which clamp the hoses are a little corroded. I'm going to get new jubilee clips for the hose and see if that helps. If not I think i'll put it down to the BG244k. Maybe it cleaned the fuel lines a bit tooooo well and removed some deposits which were necessary to the integrity of the connections :/ Quote Link to comment Share on other sites More sharing options...
Rich Posted November 19, 2013 Report Share Posted November 19, 2013 I'm finding more and more that the original rubber hoses are perishing the minute they are touched. I suggest changing the whole hose. Quote Link to comment Share on other sites More sharing options...
