vwwinston72 Posted December 24, 2012 Report Share Posted December 24, 2012 Hi, i'm desperately looking for some help with this, my car has a wet rear seat on the passenger side of the car only at the base of the back and the rear part of the base of the seat, I can't see where its coming from, there was a small amount of water in the spare wheel compartment but that could be condensation??The carpet in the boot is bone dry the carpet in the footwells is bone dry headlining is dry, its a 1.0l sunroof model, x reg.Any help would be massively helped!!Thanks in advance! Quote Link to comment Share on other sites More sharing options...
JamesTdi Posted December 24, 2012 Report Share Posted December 24, 2012 Got rear pop out windows? Quote Link to comment Share on other sites More sharing options...
vwwinston72 Posted December 24, 2012 Author Report Share Posted December 24, 2012 no fixed rear windows, thanks for the reply. Quote Link to comment Share on other sites More sharing options...
nellytheelephant Posted December 24, 2012 Report Share Posted December 24, 2012 rear screen washer pipe i had the same problem nellytheelephant Quote Link to comment Share on other sites More sharing options...
vwwinston72 Posted December 24, 2012 Author Report Share Posted December 24, 2012 Would that not cause the boot area to be wet aswell? Quote Link to comment Share on other sites More sharing options...
SamEdwardSwain1 Posted December 24, 2012 Report Share Posted December 24, 2012 open air lupo ? Quote Link to comment Share on other sites More sharing options...
vwwinston72 Posted December 24, 2012 Author Report Share Posted December 24, 2012 open air lupo ?Not sure what this means?Thanks for the replys so far guys! Quote Link to comment Share on other sites More sharing options...
nellytheelephant Posted December 24, 2012 Report Share Posted December 24, 2012 Would that not cause the boot area to be wet aswell?depends where its split Quote Link to comment Share on other sites More sharing options...
vwwinston72 Posted December 24, 2012 Author Report Share Posted December 24, 2012 Cool, i'll have a look at that asap, where does the washer pipe run? i know you need to remove the plastic boot cover? thanks Quote Link to comment Share on other sites More sharing options...
SamEdwardSwain1 Posted December 24, 2012 Report Share Posted December 24, 2012 open air lupo is this Quote Link to comment Share on other sites More sharing options...
vwwinston72 Posted December 24, 2012 Author Report Share Posted December 24, 2012 o right, no its not one of those, it has an electric sunroof, but is otherwise totally base model non central lcoking etc... Quote Link to comment Share on other sites More sharing options...
SamEdwardSwain1 Posted December 24, 2012 Report Share Posted December 24, 2012 if i remember right from when i fitted wiring kit the rear washer pipe runs along the nearside/passenger side inner sill then up under the passenger side rear seat Quote Link to comment Share on other sites More sharing options...
SamEdwardSwain1 Posted December 24, 2012 Report Share Posted December 24, 2012 try lifting up/taking out the rear seats then use the rear washers see if any thing happens Quote Link to comment Share on other sites More sharing options...
Al3xTee Posted December 24, 2012 Report Share Posted December 24, 2012 Rear washer detached behind trim on passenger side rear, I had the same problem! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 24, 2012 Report Share Posted December 24, 2012 As said, it will be the washer pipe, the upright bit of trim next to the seats pulls off and it's behind there Quote Link to comment Share on other sites More sharing options...
