Numberplate LED's.. *Scratching Head*
MoloneyGti
Hi all,
I bought these not so long ago, I was thinking they would be easy to fit.
http://www.ebay.co.uk/itm/VW-Golf-MK6-MK5-MK4-Lupo-Phaeton-Scirocco-Polo-LED-License-Number-Plate-Light-L9-/190642420063?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c632c795f#ht_1549wt_952
Anyone know how to get the number plate light housing out of the rear bumper? As i can only get the inner part off (As in where the bulbs are housed) Any chance i can take the black holders out of the bumber to slot these in?
Any input would be appreciated..
Many Thanksssssssssssssss
- Moloney
From memory i thought there was just two screws then the plastic just pulled out with a bit of wiggling
the light he's got actually replaces the whole unit! And supposedly plugs into the loom!
if you wait long enough, the clip that holds them in will go brittle and they will fall out anyway!
They don't remove the bumper to change number plate lamps here, the holder has a plastic spring clip that you push in and the hole unit comes down.
