kalum-arosa Posted April 29, 2012 Report Share Posted April 29, 2012 Can anyone give me a step by step order on how to remove my rear adjusters please??Thanks Quote Link to comment Share on other sites More sharing options...
blister Posted April 29, 2012 Report Share Posted April 29, 2012 seriously?did you fit them yourself? if so its as easy as just not putting them underneath the spring Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted April 29, 2012 Report Share Posted April 29, 2012 Jack up , wheels off , loosen bottom bolts, axle will swing down, remove adjuster, push axle back up making sure the springs seat, bolt back up, wheels back on. Quote Link to comment Share on other sites More sharing options...
Ashh Posted April 29, 2012 Report Share Posted April 29, 2012 Jack up , wheels off , loosen bottom bolts, axle will swing down, remove adjuster, push axle back up making sure the springs seat, bolt back up, wheels back on.Why wheels off? Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 29, 2012 Report Share Posted April 29, 2012 Easier to work on Quote Link to comment Share on other sites More sharing options...
Ashh Posted April 29, 2012 Report Share Posted April 29, 2012 Really? never really found it difficult with wheels on? aha Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 29, 2012 Report Share Posted April 29, 2012 Well keep yours on then and stop nitpicking Quote Link to comment Share on other sites More sharing options...
Ashh Posted April 29, 2012 Report Share Posted April 29, 2012 Well keep yours on then and stop nitpicking Was just curious Quote Link to comment Share on other sites More sharing options...
kalum-arosa Posted April 29, 2012 Author Report Share Posted April 29, 2012 No i did not fit them i had it done by a garage, i have a good idea how to remove the its just i want to be certain its correct l. Quote Link to comment Share on other sites More sharing options...
kalum-arosa Posted April 29, 2012 Author Report Share Posted April 29, 2012 Jack up , wheels off , loosen bottom bolts, axle will swing down, remove adjuster, push axle back up making sure the springs seat, bolt back up, wheels back on.Thanks mate this is what i thought i jus wanted too be certain Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 29, 2012 Report Share Posted April 29, 2012 it takes 15 minutes max Quote Link to comment Share on other sites More sharing options...
patroddy Posted April 29, 2012 Report Share Posted April 29, 2012 scotty missed an important stage "make brew" .... Quote Link to comment Share on other sites More sharing options...
Ashh Posted April 29, 2012 Report Share Posted April 29, 2012 Always handy to ensure threads visible are clean to make taking the adjusters off Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted April 29, 2012 Report Share Posted April 29, 2012 (edited) And if you need new bolts ring vw rather than asking on a forum lolSorry about forgetting the brew bit , I'm not a tea drinker so really should have thought of my list for the masses Edited April 29, 2012 by scotty_82 Quote Link to comment Share on other sites More sharing options...
patroddy Posted April 29, 2012 Report Share Posted April 29, 2012 Sorry about forgetting the brew bit , I'm not a tea drinker so really should have thought of my list for the massesfor this you are forgiven haa yer there are 2 important brew stages, at the start so as you are warm when its cold outside, and at the end so you can stand in the windows with a brew feeling smug at a good job you did Quote Link to comment Share on other sites More sharing options...
blister Posted April 29, 2012 Report Share Posted April 29, 2012 Jack up , wheels off , loosen bottom bolts, axle will swing down, remove adjuster, push axle back up making sure the springs seat, bolt back up, wheels back on.no mention of doing a risk assessment or a health and safety surrounding enviroment assesment! Quote Link to comment Share on other sites More sharing options...
kalum-arosa Posted April 30, 2012 Author Report Share Posted April 30, 2012 So the springs jus sit in the cups correct? Quote Link to comment Share on other sites More sharing options...
craigg!! Posted May 2, 2012 Report Share Posted May 2, 2012 So the springs jus sit in the cups correct?Correct Quote Link to comment Share on other sites More sharing options...
kalum-arosa Posted May 2, 2012 Author Report Share Posted May 2, 2012 Finally got it done took all of 20mins including making a brew:D Quote Link to comment Share on other sites More sharing options...
