morganvw1 Posted March 18, 2012 Report Share Posted March 18, 2012 As above, anyone done this and whats involved?Any links would be a bonus.ThanksScott Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted March 19, 2012 Report Share Posted March 19, 2012 You'll need the engine, gearbox, ecu and everything needed to make it run, alternator etc, engine loom, mabey drivshafts.It's one of the easier engine swaps, though the only engine that will "drop in" is the same one as standard. Quote Link to comment Share on other sites More sharing options...
morganvw1 Posted March 19, 2012 Author Report Share Posted March 19, 2012 I have been asked if I want a rear ended Polo with this engine in, so I think everything is there. Will the engine fit onto the existing engine mounts? Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted March 19, 2012 Report Share Posted March 19, 2012 The mounts are the same on both engines as far as I'm aware Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted March 19, 2012 Report Share Posted March 19, 2012 If you've been offered a rar ended plo then go for it.You'll have everything you'll need, it's the way I want to do the swap. lolAs above, the engine mounts are the same. Quote Link to comment Share on other sites More sharing options...
morganvw1 Posted March 19, 2012 Author Report Share Posted March 19, 2012 Thanks guys. I take it I can use the breaks off the polo for a bit more stopping power or should I go for VR6 calipers? Should I upgrade the servo or will mine do the trick. Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted March 19, 2012 Report Share Posted March 19, 2012 If you've got the bits, put all the polo stuff on the lupo.You can upgrade the front to g60 disks and calipers. Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted March 19, 2012 Report Share Posted March 19, 2012 Also if you've got a 1.4 75hp then you'll need the hubs off the polo gti to convert the brakes. Having the full car is definately the way to go about it as its all there.Plus you can sell bits to get some money back. Quote Link to comment Share on other sites More sharing options...
heartagram Posted March 19, 2012 Report Share Posted March 19, 2012 Basically reshell the Polo into your Lupo and it will be all good. Quote Link to comment Share on other sites More sharing options...
Rich Posted March 19, 2012 Report Share Posted March 19, 2012 If you have half an idea what you're doing and you aren't being optimistic about doing it in a weekend then you'll be fine. Quote Link to comment Share on other sites More sharing options...
morganvw1 Posted March 19, 2012 Author Report Share Posted March 19, 2012 Thank you so much gents. Quote Link to comment Share on other sites More sharing options...
iMation Posted March 20, 2012 Report Share Posted March 20, 2012 Again thanks for the info in here peeps Quote Link to comment Share on other sites More sharing options...
memousey Posted April 3, 2012 Report Share Posted April 3, 2012 The 1.4 box will fitt and if you get carbs it will run on your standard loom you can use your altanator aswell just get a block if not I have a gti engine loom and ecu £50 Quote Link to comment Share on other sites More sharing options...
memousey Posted April 3, 2012 Report Share Posted April 3, 2012 We put one in mine in a day! Quote Link to comment Share on other sites More sharing options...
