David Posted January 4, 2012 Report Share Posted January 4, 2012 Key will not turn either way in the lock. How can this be replaced but still allow me to keep the original key?Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Jace_b Posted January 4, 2012 Report Share Posted January 4, 2012 lupoboz is your man in the traders area. Quote Link to comment Share on other sites More sharing options...
James827 Posted January 4, 2012 Report Share Posted January 4, 2012 take off the back plastic thing on the back of the boot and look at the mechanism Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted January 4, 2012 Report Share Posted January 4, 2012 Have you tried spraying some WD40 in the key hole and on the key then trying to turn the lock with your key? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 4, 2012 Report Share Posted January 4, 2012 Dont use WD40, use Plusgas or something Quote Link to comment Share on other sites More sharing options...
David Posted January 5, 2012 Author Report Share Posted January 5, 2012 I've tried WD-40 and other penetration oil. Made no difference Quote Link to comment Share on other sites More sharing options...
Koop Posted January 5, 2012 Report Share Posted January 5, 2012 My boot lock doesn't work as it's from a different lupo, I've been thinking of getting a de-lock kit for the passenger door & moving the lock barrel to the boot if it will fit - anyone know if the lock barrels are the same? cos that would sort me & our dave out proper stylee. Quote Link to comment Share on other sites More sharing options...
eurosa Posted January 5, 2012 Report Share Posted January 5, 2012 mine wouldnt do anything when i put the badge and mech back together after painting the badge.. Lucky for me a didnt put the plastic back on the inside of the boot so was an easy fix to open. As has been said wd40 sorted out the problem for me to. Quote Link to comment Share on other sites More sharing options...
