Pete Posted January 22, 2011 Report Share Posted January 22, 2011 Hiya you lot, anyone done this and willing to take me through it step by step? Went to do it last night but have no idea which bungs I wanna be taking out or where to fill it up!! Cheers! Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 22, 2011 Report Share Posted January 22, 2011 Did it a while ago and there are some threads on it...............I have a pit in my garage which is very useful as it has to be level when filling.Basically under tray off and look at the rear ot the box.2 alloy lugs oneither side............one is higher than the other and will require a M16 security spline bitUndo the higher inside one first as this is the filler and you want to make sure you can refill the box before draining it.Once that is ok, undo the outside lower one to drain the box.............when done, plug it up again and fill until oil comes out the hole. When the oil stops flowing out and is level with the fill hole, seal it up and job done. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 22, 2011 Author Report Share Posted January 22, 2011 Ah, it is those ones then!! Thought it could be but never seen a bung like that before!! Thanks loads Mike. Quote Link to comment Share on other sites More sharing options...
mat.m. Posted January 23, 2011 Report Share Posted January 23, 2011 What oil did you use? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 23, 2011 Author Report Share Posted January 23, 2011 Genuine VW stuff mate, still got a bottle in my garage if you want the part no. Quote Link to comment Share on other sites More sharing options...
mat.m. Posted January 23, 2011 Report Share Posted January 23, 2011 yes please!! Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 23, 2011 Report Share Posted January 23, 2011 Genuine VW stuff mate, still got a bottle in my garage if you want the part no.Yeah and the spec. lol Probably antifreeze after seeing what a dealer gave my friend this week. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 23, 2011 Author Report Share Posted January 23, 2011 It's G 052 171 A2 lads. Quote Link to comment Share on other sites More sharing options...
mat.m. Posted January 23, 2011 Report Share Posted January 23, 2011 Cheers! BTW, what size bottle is it and how many litres did it take to fill her up? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 23, 2011 Author Report Share Posted January 23, 2011 They come in 1 ltr tubs mate and 2 should suffice, Quote Link to comment Share on other sites More sharing options...
mat.m. Posted January 23, 2011 Report Share Posted January 23, 2011 Thank you very much Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 24, 2011 Report Share Posted January 24, 2011 Ah, it is those ones then!! Thought it could be but never seen a bung like that before!! Thanks loads Mike.No problem Quote Link to comment Share on other sites More sharing options...
JasperIrl Posted September 29, 2021 Report Share Posted September 29, 2021 Thread revival! 🙂 Doing an oil change on the GTI and got G 052 527 A2 from VW, but I see above says a different oil? G 052 171 A2 Anyone know the difference or if OK to use? Cheers Quote Link to comment Share on other sites More sharing options...
