adr1ch Posted October 5, 2010 Report Share Posted October 5, 2010 ma mates got his old corsa c wheels and im thinkin about buyin em for wintersanyone had a set on before i know there 4x100 and the et is low so would need spacing but just wondered if anyone had tried em?? Quote Link to comment Share on other sites More sharing options...
adam lupo Posted October 5, 2010 Report Share Posted October 5, 2010 my mates got my old lupo wheels on his corsa while he gets his power coated . fit straight on .... so i wd assume corsa wheels wud go on a loop Quote Link to comment Share on other sites More sharing options...
adr1ch Posted October 5, 2010 Author Report Share Posted October 5, 2010 no bother thanks dudethey remind me of the arosa s wheels tooshould be ok for thru the winter with potenzas on Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 5, 2010 Report Share Posted October 5, 2010 The lower the offset the more sticky out.They're likely going to be 38-49, so depending on width you sould be able to use a spacer upto 20mm anyhow.Possibley 25mm if they are ET49. Quote Link to comment Share on other sites More sharing options...
adr1ch Posted October 5, 2010 Author Report Share Posted October 5, 2010 sorry im a tool i meant the et will be high thanks lolthink ill got for 20mm or over got some cheap and nasty 10mm ones atm ill see what happens thanks people Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 5, 2010 Report Share Posted October 5, 2010 My bathursts are 6.5" ET43 with 195\45\15 tyres. I am running 20mm spacers on the rear, giving me ET23, and I only foul when loaded or on the largest of bumps. Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted October 5, 2010 Report Share Posted October 5, 2010 Check out the centre bores before you commit to buying them.I think the Vauxhall bore might be smaller than VW, therefore they wont fit. Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted October 5, 2010 Report Share Posted October 5, 2010 .25mm all around is **** all thats prob the thickness of the powder coat, get a dremel into it and itll be reet Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted October 5, 2010 Report Share Posted October 5, 2010 renault wheels will fit, may need spigots, and spacer, but will fit! any pics? Quote Link to comment Share on other sites More sharing options...
adr1ch Posted October 5, 2010 Author Report Share Posted October 5, 2010 these are the types im meaning probs will just get a dremel on the job why not they dont need to be perfect i supposegonna either do em all black or everone a different colour Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted October 5, 2010 Report Share Posted October 5, 2010 like! Quote Link to comment Share on other sites More sharing options...
adr1ch Posted October 5, 2010 Author Report Share Posted October 5, 2010 should be ok with 165/50/15 potenzas on the front and keep the standard 185/50/15 p6000s on the rear as 2 need changedduno about going over 30mm for spacers tho Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 5, 2010 Report Share Posted October 5, 2010 Has anyone though of running the delivery steels that vauxhalls seem to be on now , they look like some sort of 5 spoke design alloy but are actually a steely .I've not been able to find a picture of them yet online.They would look pretty sick banded but im also not sure if they do them in 4 stud as vie only seen them in 5 so far. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 6, 2010 Report Share Posted October 6, 2010 Ah right , i thought they were just delivery wheels.Im going to see who if i know anyone working for them and see if i can get a set in 16s for my bros mk3.Ill have to check up on width and offset etc first.Still cant find any pics of them though. Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted October 6, 2010 Report Share Posted October 6, 2010 The VW hub centre bore is 57mm, whereas the Vaux centre bore is only 56mm, so they definitely wont fit straight on.You'd have to get them machined out. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 6, 2010 Report Share Posted October 6, 2010 Cheers , i knew the bore was smaller but was not sure on width and offset on the insignias etc Only takes a few mins with a sanding attachment sot sort 1 mm out . Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 6, 2010 Report Share Posted October 6, 2010 Just checked , insignia is 5x120 and the newer shape astras are 5x110 with the usual high offsets. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 6, 2010 Report Share Posted October 6, 2010 BANGhttp://cgi.ebay.co.uk/2009-VAUXHALL-INSIGNIA-17inch-Wheel-Steel-/350384832501?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5194903ff5#ht_1642wt_1113 Quote Link to comment Share on other sites More sharing options...
Philplop Posted October 6, 2010 Report Share Posted October 6, 2010 Some focus' have wheels like that too, they look like alloys but they're hubcaps and shaped steels. Good idea really. What are new Fords? 5x108? Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted October 6, 2010 Report Share Posted October 6, 2010 (edited) Yeah i think the new ford range is still 4x108 for the smaller models and 5x108 for the larger ones. Edited October 6, 2010 by scotty_82 Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 28, 2010 Report Share Posted October 28, 2010 (edited) vaux centre bore is lower than vw isnt it?? Edited October 28, 2010 by max West-York Quote Link to comment Share on other sites More sharing options...
