Compomotive TH mono's
Humbaz
yes mate, if you do go for them make sure you get the right e.t
i think mine are e.t 38 or 37 that fit spot on and just about tuck with mininal rubbing when cornering hard or through dips in the road
but im sure you can get 28 or 27 that will rub if the loop is low, and i think will need some tyre stretch and or arch work to get them under.
hope this helps!
  • 2 months later...
