BEP51 Posted September 28, 2010 Report Share Posted September 28, 2010 Why not get 30mm lowering springs?i would, but i am more intersted in reducing body roll than lowering. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 28, 2010 Report Share Posted September 28, 2010 i would, but i am more intersted in reducing body roll than lowering.GTI front anti roll bar then would be better, cheap coilovers will just spoil the ride. Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted September 30, 2010 Report Share Posted September 30, 2010 (edited) ARBLook here Edited September 30, 2010 by LUKEY BOI Quote Link to comment Share on other sites More sharing options...
BEP51 Posted September 30, 2010 Report Share Posted September 30, 2010 would a rear anti roll-bar help with roll at the front? and are they an easy, quick fit? Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 4, 2010 Report Share Posted October 4, 2010 (edited) Hi, im getting a lupo next month and im wanting to put it straight on to coilsIt will be a 1.4l but i will be using it on the motorway a lot, would TA techs be the way to go or should i opt for a better brand since ill be running halifax to leeds on the motorway 2/3 times a weekAlso, for the same reason, whats the most you would recommend lowering it?Thanks, Max Edited January 5, 2011 by max West-York Quote Link to comment Share on other sites More sharing options...
Paul_c Posted October 4, 2010 Report Share Posted October 4, 2010 (edited) Hi, im getting a lupo next month and im wanting to put it straight on to coilsIt will only be a 1.0l but i will be using it on the motorway a lot, would TA techs be the way to go or should i opt for a better brand since ill be running atleast 70mph 2/3 times a weekAlso, for the same reason, whats the most you would recommend lowering it?Thanks, MaxThe product you buy will depend on your budget really Buying TA over something more expensive shouldn't effect high speed motorway stability.You may want to reconsider your 'atleast 70mph' speeds, although it can do morethe 1.0l seems to be happier at 60mph tbh! -80mm seems sensible to me just depends on your roads and what wheels/offset you run.. Edited October 4, 2010 by Paul_c Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted October 4, 2010 Report Share Posted October 4, 2010 will these coilovers actually reduce body roll? i only plan to lower by 35mm tops on my lupo, cos i mainly want to stop it rolling so much at the front.Yo Plymouth dude!I have these and on my run of the mill 1.4E, it reduced body roll. I couldnt comment on a Sport. Plus, you have a nice car as standard, being a Sport, whether or not you want cheaper lows, or more security paying that bit more.And if you only want 35mm, and no chance of ever going lower, best off getting 40mm lowering springs. Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 4, 2010 Report Share Posted October 4, 2010 (edited) The product you buy will depend on your budget really Buying TA over something more expensive shouldn't effect high speed motorway stability.You may want to reconsider your 'atleast 70mph' speeds, although it can do morethe 1.0l seems to be happier at 60mph tbh! -80mm seems sensible to me just depends on your roads and what wheels/offset you run..hahawell budget isnt loads bout 300-400 inc fitting unless i can do it myself?ive heard mixed reviews on TAs but a lot more positive feedback on APshah yeh might have to sit in the outside lane for a change 80mm should be enough for me but im gna be running14x8 et25/30 (depending on which is better as ive got loads of spacers)with 195/45/14 (about 30mm stretch from tread to lip) on the backs and 14x7 et30/35 again depending, also with 195/45/14 hardly any stretch on the frontthat should be okay for not rubbing right?or will i need some arch work doing? hopefully only need rolling as i dont have the money to mess about with flaring atm ;D Edited October 4, 2010 by max West-York Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted October 4, 2010 Report Share Posted October 4, 2010 If you can stretch to a little over £400 then you can get AP coilovers.Not heard a bad thing about them. They've done me good for a year now. Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 4, 2010 Report Share Posted October 4, 2010 did you get them professionally fitted or is it possible to do it yourself?dno whether to get AP or TAs cos its a big difference in price and some people seem to have had good runs with technics, just that the bad reviews are putting me off thats all :| Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted October 4, 2010 Report Share Posted October 4, 2010 I fitted them with a bit of help form my dad. Hardest thing to deal with was getting the topmounts the orig struts but, Ive heard that you can get them pretty cheap off VW.From what Ive read and my exprience running APs, they are much better than the TAs in terms of road comfort and ride. Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 4, 2010 Report Share Posted October 4, 2010 i might have to see if i can find some cheap APs then!Gna try save up as i wont be driving it until the 17th of nov anyway so i can leave it on stilts until then Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 5, 2010 Report Share Posted October 5, 2010 wow haha, how much has all that set you back? i dont care about performance, its gonna be my daily so as long as shes riding comfortably low im happy im getting TA or AP coils i think, cant really afford much better atm and i havnt heard much about the v-maxx setup ive heard dampers with the AP are good but TA dampers arent great though, thats the only thing putting me off atm Quote Link to comment Share on other sites More sharing options...
Kez1990 Posted October 5, 2010 Report Share Posted October 5, 2010 my TA's are quite good tbh noffin bad bout them imo, indeed they are cheap and i have heard bad reviews, just somthing to run until i can afford better quality ones.TA's = Cheap affordable slammage! Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 5, 2010 Report Share Posted October 5, 2010 Ha a small fortune but worth every penny. If i had that choice it would be AP coilies for me. V-maxx are probably on par with TA ones.yeh they dont give me a good vibe and for 100 more than TAs i didnt see the point, gna try save for APs and if not, just risk TAs and hope for the best! Quote Link to comment Share on other sites More sharing options...
smye87 Posted October 6, 2010 Report Share Posted October 6, 2010 (edited) If you can stretch to a little over £400 then you can get AP coilovers.Not heard a bad thing about them. They've done me good for a year now.I went to Halfrauds today (I have ****ty gift vouchers - my apologies if this offends any employee reading this!) and enquired about coilovers. They have an instore magazine that does performance parts; I got a quote for the AP ones and they were over £400, I can't remember the fully price because I was just a bit shocked to hear the figure.I'm on the lookout for coilovers now, although I should probably save my money. I'm just a bit impatient. If I did manage to get some at bargain price, I'd probably buy them and then keep them stored till Summer '11, by then I may have other things sorted for the car. It's a tough call buying coilovers IMO if you've never had experience of coilover brands before and/or money is an issue.Smye Edited October 6, 2010 by smye87 Quote Link to comment Share on other sites More sharing options...
max West-York Posted October 7, 2010 Report Share Posted October 7, 2010 I went to Halfrauds today (I have ****ty gift vouchers - my apologies if this offends any employee reading this!) and enquired about coilovers. They have an instore magazine that does performance parts; I got a quote for the AP ones and they were over £400, I can't remember the fully price because I was just a bit shocked to hear the figure.I'm on the lookout for coilovers now, although I should probably save my money. I'm just a bit impatient. If I did manage to get some at bargain price, I'd probably buy them and then keep them stored till Summer '11, by then I may have other things sorted for the car. It's a tough call buying coilovers IMO if you've never had experience of coilover brands before and/or money is an issue.Smyewell it turns out ill have enough to get APs when i get my loop so it should be sitting on them within the first week Quote Link to comment Share on other sites More sharing options...
