cookymunster Posted February 9, 2010 Report Share Posted February 9, 2010 HAZARD SWITCH / INDICATOR RELAY CLICKING ALL THE TIMEI have basically managed to fix the annoying constant or intermittent clicking from the Hazard Switch / Indicator Relay. Yes the problem lies with a worn out contact in the Indicator Stalk or Indicator Leaver which I took apart, cleaned and soldered a very small nipple back onto the contact that had worn off. Without this little nipple making contact I guess the stalk was not turning the relay off properly. The following is how I did it and what tools I used.TOOLS:1. 24mm Socket with 1/2 inch Wrench2. Hex Screw Head Set3. Flat Head Screwdriver4. Phillips Head Screwdriver5. Solder and Soldering Iron6. Fine Emery Cloth7. Wire Brush1. Take off steering column Covers. One Hex screw and two Phillips head screws underneath. Then prize apart the 2 covers to remove.2. Un-clip the airbag wire harness. It should be to the left of the column and holds the wires that rotate around the rear of the steering wheel. This is instead of disconnecting the battery. Be sure to reconnect on re-assemly!!3. REMOVE STEERING WHEEL:- Insert key into ignition, and turn to the "on", but not "over" position (this will keep the wheel from locking).- Turn the wheel 90 degrees to one side. You will feel/see a small hole in the back.- Insert a small flathead screwdriver into the hole. Make sure the screwdriver is angled such that the handle is against the steering column, and the flathead is as high up within the hole as possible. Make sure to push the screwdriver in as far as you can.- Pull up on the handle. What you are trying to do is push down on a small spring within the steering wheel that holds the airbag locking latch secured.- You may have to try a couple times, but you will eventually see, hear, and feel the airbag catch release from the spring.- Turn the wheel in the opposite direction 180 degrees until you can see/feel the second hole.- Repeat the screwdriver procedure.- The airbag and horn should now be released from the steering wheel. However, Horn & Airbag still attached to their wiring harnesses. I managed to leave these connected and balance the airbag while undoing the steering wheel nut. Then the whole ting comes off together with wiring intact.Otherwise make sure to unplug the harnesses from the airbag and horn before you pull it out too far from the wheel. Be sure to reconnect on re-assemly!!.- Use the 24mm Socket to undo the Lupo Steering Wheel Nut and Steering Wheel will come free.4. Un-clip the indicator wiring harnesses from left and right sides of the steering column.5. Undo the 3 screws to free the indicator stalk from the windscreen wiper stalk and pul free.6. Take the stalk to your cleaning area where you can arrange the bits we are going to dismantle. Don't worry as below should be pictures I've done to help you through dismantling and reassembly.7. Undo the one screw on stalk case. Gently unclip the 3 little clips around the case. The case is still held together because of a copper terminal running through both halves of the case. You need to push the protruding copper prong back through its hole with a pair of pliers, being careful not to bend it. The case will prize apart now.8. Basically we need to clean all terminals of grime and rub them clean with the emery cloth.9. The main thing on mine was to re-solder a nipple onto the terminal / brush on the Stalk as shown in the picture below. P.S. These pictures are from my server so they may not be around for ever. I wish Club Lupo could host them!!! 1 Link to comment Share on other sites More sharing options...
mk2 Posted March 19, 2016 Report Share Posted March 19, 2016 (edited) This afternoon, I decided to sort my annoying clicking indicators and random wiper action. So I took some shots while I was working. Three hours will cover you working at a leisurely pace. Some pics to add... 🙂 Use a sharp blade or craft knife to shave a bit of plastic off.   And to reassemble, do the exact reverse. The Airbag module slots in at the bottom edge then you simply press it in place till it clicks. Do not turn power on while airbag is disconnected. If in doubt disconnect the battery to be safe. Edited April 12, 2020 by mk2 pics update 1 Link to comment Share on other sites More sharing options...
Mobieus_uk Posted March 22, 2016 Report Share Posted March 22, 2016 nice write up, thanks for taking the time to document it, I've got to do mine i will probably cheat and replace both stalks but handy to know how to get the airbag bit off Link to comment Share on other sites More sharing options...
Grazza Posted April 14, 2016 Report Share Posted April 14, 2016 nice write up, any info on the rear wiper button? whenever mind is caught accidently the wiper goes crazy and keeps stopping during the sweep of the blade Link to comment Share on other sites More sharing options...
carrera-gt Posted April 16, 2016 Report Share Posted April 16, 2016 Stopping during wiping is normally an issue with the switch in the wiper gearbox Link to comment Share on other sites More sharing options...
