project Arosa / budget dog
olethalb
thanks bud. :)
right i think i'm changing my mind again, i've been looking around for a 1.6 8v or 1.4 16v mk4 polo lump to drop into the arosa, the problem is it'll cost around £300 for an average engine/ box/ loom/ ecu etc, then it'll have to have a 4 branch and bike carbs etc so i'll be looking at £800 - 900 for roughly 120bhp. i reckon i could buy and fit a 1.8t for around the 1k mark wich will be 150 bhp out of the box and map for 50 - 70 bhp more.
i'm not sure what i'm going to do with it now, i sold the ful tank and for now i'm going to concentrate on the bodywork until i make my mind up.
opinions??
Olly
I have never driven a 20VT Lupo I can imagine it being above the usable power and weight band for
such a small and light car. maybe okay in straight line but i think it'd take the fun out of
taking it around the twisties.
what about a 1.9TDI... Did I do a dirty word?
yes diesel is a dirty word! lol!
right lowered the rear earlier
when i bought it it already had chopped springs that were cable tied in place, this was the ride height
the main problem with chopping springs is when you jack it up the shock extends (as below) and the spring falls out or off the seat
this is the chopped down spring length just before it drops off the seat (no weight on it)
now i need to go lower (lower than coilys can manage either) so the springs will need to be shorter, the problem is i can't be doing with the springs dropping off everytime i jack it up, so the only solution is to fit shorter shocks
as you can see the travel isn't much shorter but the overall length is reduced
these shocks are not vag items and the bottom mounting is narrower than the arosa items, so a 4-5mm spacer is needed
this will need to be fitted in the inner edge of the beam
i lopped a bit off the springs (not alot - you'll se why at the end) that were already chopped down
with both shocks and springs fitted this is the length of the spring in place under 30+ mm of compression but the wheel off the ground just the shorter shock compressing the spring and holding it in place
so now this is the tyre to arch gap with the wheels off the ground and the shocks fully extended
now i could go another 20-30mm drop in the following pics but as you'll see i need more wheels before i do that
Olly
i'm going to try and keep the bora Kam, it's the longest i've ever owned a car - 1 year in feb!! i'll probably stop using it as my daily and get it up to show spec.
i'll use the arosa too beat about (daily) and do some stupid things to it.
Olly
decided to strip out the rear trim earlier
if there's any trim in the above pic you want just let me know
also srtipped the cards off
next part to be removed was the rear seat mount, i drilled out all the spot welds
and pulled it off
thats all for now
Olly
haha - as i said at the start it's just a budget box, something to not take too seriously or worry about being able to sell on.
i've decided not to 1.8t it for that reason - it would all get too serious and involved, i should be picking up another small block lump this weekend and will do some more body mods in the coming weeks.
budget box cost so far;
car - £130
coily's - £50
256mm hubs, calipers, b/n gen vw bearings and ebc pads - £20
256mm b/n discs - £35
shorter rear shocks - £free
16v arb - £free
bbs alloys - £free
so far we're upto the grand total of....£235
obviously engine will wack it up a bit but i'll update it as i go and don't want to go over 1K total.
oh engine should be out this week so if you need any 1.0 bits let me know.
Olly
1 of them is forked bud, the tyres are all nearly new though (pirelli's and goodyears) i need to sell them on to get something more suitable, i was going to bay them for £25 each and £15 for the 4th tyre off the knackered rim.
Olly
