crash Posted July 16, 2009 Report Share Posted July 16, 2009 Seen some 8 inch wide bbs splits with tyres...any one know if these wide mothers would be ok on my gti? they are 15" and 4x100 pcd so thats ok....just the 8" part I am not sure about!!???....cheers for ya help chaps and chappesses. Quote Link to comment Share on other sites More sharing options...
cobblers Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) If the offset is reasonable they'll fit fine. Use something like 195/45/15s.They would fit a non-gti, and you have bigger arches Edited July 16, 2009 by cobblers Quote Link to comment Share on other sites More sharing options...
crash Posted July 16, 2009 Author Report Share Posted July 16, 2009 If the offset is reasonable they'll fit fine. Use something like 195/45/15s.They would fit a non-gti, and you have bigger arches thanks cobblers!yeah i thought they might squeeze in/on...just checking the offset and tyre size now! Quote Link to comment Share on other sites More sharing options...
.Phase Posted July 16, 2009 Report Share Posted July 16, 2009 yeah they sound finesome people run 9 & 10 without problems lol ! Quote Link to comment Share on other sites More sharing options...
crash Posted July 16, 2009 Author Report Share Posted July 16, 2009 yeah they sound finesome people run 9 & 10 without problems lol !haha 9 and 10 inches....crazy Quote Link to comment Share on other sites More sharing options...
Adam Posted July 16, 2009 Report Share Posted July 16, 2009 The offset won't be very good though and you may struggle at the front especially if you plan on running fairly low. Quote Link to comment Share on other sites More sharing options...
Philplop Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) I haven't seen any 9 or 10's x 15J. Usually people only run really wide wheels on 13's or 14's.GTI's have wider arches but also a wider track, so there isn't really any extra roor for wide wheels under them. In fact I'd say you can run wider wheels on a non-GTI.At a guess I'd say they're gonna be a pretty low offset, as they were probably 6.5J as standard, and around et38. Once you've added 2" dishes on them to make them 8J the offset's gonna be quite low and rather pokey. Edited July 16, 2009 by Philplop Quote Link to comment Share on other sites More sharing options...
crash Posted July 16, 2009 Author Report Share Posted July 16, 2009 The offset won't be very good though and you may struggle at the front especially if you plan on running fairly low.rolled arches you thinking?!...it will be on kw v1's so can adjust if needed... Quote Link to comment Share on other sites More sharing options...
heartagram Posted July 16, 2009 Report Share Posted July 16, 2009 The arch skins are weird on a GTI so can prove to be a problem. Or so I've read... Quote Link to comment Share on other sites More sharing options...
Philplop Posted July 16, 2009 Report Share Posted July 16, 2009 Yeah, on the rear there's about a 10mm gap between the inner and outer arches. For maximum room you'd need to cut and reweld them.If you take it somewhere to get the front arches rolled, make sure they know they're aluminium, as you need to be more careful with them as they're brittle. I just cut the front arches back so there's only a little lip. Quote Link to comment Share on other sites More sharing options...
OPS Posted July 16, 2009 Report Share Posted July 16, 2009 I reckon they will be fine with the right size tyre on there. offsets everything at the end of the day Quote Link to comment Share on other sites More sharing options...
foxy Posted July 16, 2009 Report Share Posted July 16, 2009 I ran 8j ET18 wheels on standard arches. The car was undriveable. Quote Link to comment Share on other sites More sharing options...
pro3mark Posted July 16, 2009 Report Share Posted July 16, 2009 I ran 8j ET25 wheels on standard arches. The car was fine. I ran 8j ET25 wheels on standard arches with 25mm spacers. The car was then undriveable and cut rather large grooves out of the tires. Quote Link to comment Share on other sites More sharing options...
foxy Posted July 16, 2009 Report Share Posted July 16, 2009 Thus proving its all about the offset Quote Link to comment Share on other sites More sharing options...
Mr ColinG Posted July 16, 2009 Report Share Posted July 16, 2009 I run 8" the offset is ET13, I had to roll and pull the arches.Tyres are 195/45x15 Quote Link to comment Share on other sites More sharing options...
Philplop Posted July 16, 2009 Report Share Posted July 16, 2009 I had 8j et25 with 205/45's. It scrubbed even when riding sky high.Running the same wheels with 165/50's I can run mega low with no scrubbing.Depends a lot on ride height too. What some people class as low isn't low to others, and everyone seems to guess their ride height measurements so that's no good either.If you like the wheels. Make them fit. Quote Link to comment Share on other sites More sharing options...
crash Posted July 20, 2009 Author Report Share Posted July 20, 2009 Thanks for all the input everyone! ended up not getting the rims as the guy wanted silly money and they werent as 'perfect' as he had said!I have a mate of a mate with a mk1 golf gti and hes selling his wheels. They werent really legal on his car to be honest so am not sure if they would fit the lupo either?!...they are 15x7, 4x100pcd and et13 what do you think?...fit?!thanks in advance peeps! Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 20, 2009 Report Share Posted July 20, 2009 Hmm, ET13 are going to stick out a bit too far to be honest matey Quote Link to comment Share on other sites More sharing options...
crash Posted July 20, 2009 Author Report Share Posted July 20, 2009 Hmm, ET13 are going to stick out a bit too far to be honest matey owwww! back to the drawing board! did think they might be a little too pokey outy! cheers matey. Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted July 20, 2009 Report Share Posted July 20, 2009 they are 15x7, 4x100pcd and et13 what do you think?...fit?!thanks in advance peeps!u would get those on. the 8s u were planning if they were bbs rms r 15x8 et 14 and as bluloop said he got them on with work, so with an inch less width u'll have no problems.. Quote Link to comment Share on other sites More sharing options...
OPS Posted July 20, 2009 Report Share Posted July 20, 2009 I ran 8x 13's on my lupo with et-1 it's all about Et and tyre profiles, anythings do able its just how much effort and work you need to put in to make them fit. Quote Link to comment Share on other sites More sharing options...
Philplop Posted July 20, 2009 Report Share Posted July 20, 2009 13's are easy to go wide on, the arch sits above them.I have a set of 15x7's et30, and they scrub quite a bit on 195/45's. Was quite surprised actually. Quote Link to comment Share on other sites More sharing options...
Philplop Posted July 20, 2009 Report Share Posted July 20, 2009 13's are easy to go wide on, the arch sits above them.I have a set of 15x7's et30, and they scrub quite a bit on 195/45's. Was quite surprised actually.The difference between 8J et 13 and 7J et13 isn't an inch. The face will only stick out half an inch further, the other half an inch will be on the rear side of the wheel, next to the suspension. Quote Link to comment Share on other sites More sharing options...
crash Posted July 23, 2009 Author Report Share Posted July 23, 2009 UPDATE!...What do we think of Keskins and imparticular RT5's - 16 x 7.5" et20 4x100pcd????Think theyd look pretty good on a silver lupo gti?!?!!?!??!!?RT5's Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted July 23, 2009 Report Share Posted July 23, 2009 someone had them on a standard lupo i believe..aint seen them on a gti though/.. Quote Link to comment Share on other sites More sharing options...
