criddy Posted February 25, 2009 Report Share Posted February 25, 2009 my lupo s keeps cutting out but only when your sat in traffic or not moving its started to do it a little bit now driving at very low speeds.iv changed the spark plugs and ht leadsbut no diffrent any suggestions?cheers Quote Link to comment Share on other sites More sharing options...
jack1988 Posted February 25, 2009 Report Share Posted February 25, 2009 my lupo s keeps cutting out but only when your sat in traffic or not moving its started to do it a little bit now driving at very low speeds.iv changed the spark plugs and ht leadsbut no diffrent any suggestions?cheersMine does this, i have an induction kit on it and i think that that might have caused it,..... just keep revin it up!!! Quote Link to comment Share on other sites More sharing options...
loop on steelies Posted February 25, 2009 Report Share Posted February 25, 2009 mine also does this but i change plugs and leads and put a bmc box on it about a month before it started,more excuse for that induction raw at the lights;) Quote Link to comment Share on other sites More sharing options...
criddy Posted February 26, 2009 Author Report Share Posted February 26, 2009 yea i have a bmc kit aswellit crossed my mind it might be thatengine not getting enough air when its not moving.well i was gonna take it to the garage but problemsolved ill just keep reving it Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted February 26, 2009 Report Share Posted February 26, 2009 Have you cleaned out the throttle body? notorious for clogging up, leading to cutting out and crappy idling.Mine does it les and less now that it's got the bmc on, though when i had the powertech induction kit with the crank breather pipe channeled into it it used to clog every few weeks. Quote Link to comment Share on other sites More sharing options...
Niche Posted February 26, 2009 Report Share Posted February 26, 2009 Coil Pack. Quote Link to comment Share on other sites More sharing options...
LuPo SpOrTX Posted February 26, 2009 Report Share Posted February 26, 2009 If you have a BMC kit on it could be your throttle body as previously mentioned (easy to clean). However I had a problem a while back where my car cut out a few times and I found out that where I had fitted the BMC I had kinked the Crankshaft breather tube, which caused the car to cut out...Got my dad to look at it and he immediately said this could have been the cause....so may be worth a look in! Otherwise could be coil pack or lambda sensor?good luck! Quote Link to comment Share on other sites More sharing options...
SC02 FFF Posted February 26, 2009 Report Share Posted February 26, 2009 doubt ur bmc, although it might be a sensor / tb tripping out maybe? im no mechanic Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted February 26, 2009 Report Share Posted February 26, 2009 I have the cure for you sonny!Clean the throttle body/idol valve and the breather unit.Mine was a constant problem like 3/4 times every journey no matter how far, then they were both cleaned out (filthy inside!) and yeh hasnt cut out since.Do it. Quote Link to comment Share on other sites More sharing options...
criddy Posted February 26, 2009 Author Report Share Posted February 26, 2009 iv ordered a cleaning kit for the filter so im gonna give that a good cleanand ill do the throttle body aswell while im at it.gonna take it to the garage monday aswell so they can checkall the sensors and what not.cheers for all help guys Quote Link to comment Share on other sites More sharing options...
l66upo Posted February 26, 2009 Report Share Posted February 26, 2009 Try ya coolant temp sensor. Well common Quote Link to comment Share on other sites More sharing options...
tomflyer Posted February 26, 2009 Report Share Posted February 26, 2009 ditto l66upo hehe i had mine doing that and was just the temp sensor Quote Link to comment Share on other sites More sharing options...
l66upo Posted February 27, 2009 Report Share Posted February 27, 2009 id happily bet £100 its the coolant temp sensor Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted February 27, 2009 Report Share Posted February 27, 2009 my lupo s keeps cutting out but only when your sat in traffic or not moving its started to do it a little bit now driving at very low speeds.iv changed the spark plugs and ht leadsbut no diffrent any suggestions?cheersWhy is it whenenver anyone posts any problems with their car my car decides to do the exact same thing!! LOL!Mine did this this morning, i've notice it do it when it's wet actually come to think of it. I thought at first it was water splashing up to the intake since i connected the original air feed from the wing to the bmc (my inner wing is none existant) One thing i haven't put back on the car is the under tray, so water could be getting up to the coilpack as Nick stated.Things to try anyway. Quote Link to comment Share on other sites More sharing options...
Niche Posted February 27, 2009 Report Share Posted February 27, 2009 Coil packs just tend to go wrong after about 6 years minimum undertray or not, that's how often I would replace it.On the newer spec VW's they have ignition coils so there is an independant coil pack per cylinder, its kind of like an ignition lead and a coil pack slammed together. And they go wrong every 4 years.I treat it as a service part, same as other things you wouldn't think of doing such as the gearbox oil. Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted February 27, 2009 Report Share Posted February 27, 2009 I treat it as a service part, same as other things you wouldn't think of doing such as the gearbox oil.True Nick, very valid point, there is probably loads of bits that occasionally perish and deteriorate over time which normally you wouldn't think about, always thinking it was something more drastic than it is, i haven't looked at the prices of the coilpacks though, any rough prices?I hope this helps the OP out in his quest for the answer, i know we've digressed a little in the topic.CheersPete Quote Link to comment Share on other sites More sharing options...
Niche Posted February 27, 2009 Report Share Posted February 27, 2009 (edited) True Nick, very valid point, there is probably loads of bits that occasionally perish and deteriorate over time which normally you wouldn't think about, always thinking it was something more drastic than it is, i haven't looked at the prices of the coilpacks though, any rough prices?A genuine VW coil pack is about £80, I bought a non-genuine off Ebay for £40ish delivered. Done the job nicely, but I stuck to genuine ignition leads and spark plugs etc.I think the only non-genuine part I had under the bonnet was the coil pack. The coil pack cured my idle issue, when I rolled up to a junction the idle would dip briefly and then come up, almost stalled once so I got it changed.Easy job to do yourself as well. Just don't put the ignition leads back on the wrong way. Lol. Edited February 27, 2009 by Niche Quote Link to comment Share on other sites More sharing options...
billstein9 Posted March 9, 2009 Report Share Posted March 9, 2009 my lupo s keeps cutting out but only when your sat in traffic or not moving its started to do it a little bit now driving at very low speeds.iv changed the spark plugs and ht leadsbut no diffrent any suggestions?cheersmine started to do this and i found that my breather tube was blocked so i bought some carb cleaner and sprayed the carb internaly and externaly along with clearing the blockage. my loop sport never cuts out now and idles realy smoothly. hope this helps. carb cleaner was £5 and it was a 5 min job to remove filter box and spray into carb. cleaning the breather pipe took a little longer and was awful to do but its worth it. Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted March 9, 2009 Report Share Posted March 9, 2009 A genuine VW coil pack is about £80, I bought a non-genuine off Ebay for £40ish delivered. Done the job nicely, but I stuck to genuine ignition leads and spark plugs etc.I think the only non-genuine part I had under the bonnet was the coil pack. The coil pack cured my idle issue, when I rolled up to a junction the idle would dip briefly and then come up, almost stalled once so I got it changed.Easy job to do yourself as well. Just don't put the ignition leads back on the wrong way. Lol.Nick, great information as per, i shall be getting one of these methinks when some more money comes in. Shame really as the car is great in the dry, just as soon as there is any moisture in the air it starts acting loopy. Cheers. Quote Link to comment Share on other sites More sharing options...
Brammo Posted March 11, 2009 Report Share Posted March 11, 2009 Some one else had the same problem it was there coolant and speed sensor Quote Link to comment Share on other sites More sharing options...
