Rye Posted March 31, 2008 Report Share Posted March 31, 2008 I have a problem with small amounts of water coming through front speaker.. I had a paint defect on the passenger door and has it resprayed. When the idiots at VW sprayed it they must have stripped the door down and when they revitted the door back up snapped the speaker housing and instead of replacing it they just banged the door card back over typical. Here I am now a year later been back an they wont touch it..I have decided to upgrade the front speaker whilst I am in there.. First I have a question...What stops the back of the speaker getting wet? as this sits in the wet caverty of the door?I have searched all the topics thats how I located the leak and have read hows to's.. on fittings speakers just wondered if I was missing somthing to stop back of speaker getting wet.Cheers allRye Quote Link to comment Share on other sites More sharing options...
Mike_M Posted March 31, 2008 Report Share Posted March 31, 2008 There is usually a plastic helmet that cover the upper half of the speaker, but there should not be a lot of water getting in there to be honest. Sounds like some of your seals may be faulty and your door drain hole possibly blocked. Quote Link to comment Share on other sites More sharing options...
andyp Posted March 31, 2008 Report Share Posted March 31, 2008 as mikes said check that all the drain holes are unblocked as that may be the cause, ive not heard of water coming through speaker before though. Quote Link to comment Share on other sites More sharing options...
mickgbev Posted March 31, 2008 Report Share Posted March 31, 2008 i had a similar problem to this, it turned out to be that the pipe from the sunroof drainer had come off , and the water was running onto the electrics in the passenger foot well , and now my central locking doesn't work. Quote Link to comment Share on other sites More sharing options...
Matty_Gti Posted March 31, 2008 Report Share Posted March 31, 2008 yup check the drainholes arn't blocked i soundproofed over mine on my old car and caused a little puddle woops, learnt from my mistakes tho Quote Link to comment Share on other sites More sharing options...
Rye Posted March 31, 2008 Author Report Share Posted March 31, 2008 Checked all the drain holes was the first thing I thought it was..When you say "there shouldnt be much water in there" doesnt the water from the window run down the door skin and out the holes at the bottom so there should be a fair amount well there was when I tried it with a jug.So there should be a plastic cover that goes over the top will have a look cheers guys.much appreciated.Rye Quote Link to comment Share on other sites More sharing options...
