nfbr Posted April 7, 2007 Report Share Posted April 7, 2007 Typical stupid worthless peice of shít Volkswagen jack decided to keel over and stab my rear side quarter and bend the feck out of my sillanyone know how to fix it without fitting a full rear quarter?Luckily its the ****ed side anyway... Quote Link to comment Share on other sites More sharing options...
Max69vk Posted April 7, 2007 Report Share Posted April 7, 2007 Any bodyshop should be able to use a tag/slide hammer welder to pull it back out again. Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 7, 2007 Author Report Share Posted April 7, 2007 (edited) Any bodyshop should be able to use a tag/slide hammer welder to pull it back out again.Its stabbed the side with an angle, so theres a big deep "V" in the bodywork... Needs a new full rear quarter i think... Lucky its the side that was already damaged... Edited April 7, 2007 by nfbr Quote Link to comment Share on other sites More sharing options...
Max69vk Posted April 7, 2007 Report Share Posted April 7, 2007 Get some pics up, Im certain it'll be repairable from what you've decribed. Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 7, 2007 Author Report Share Posted April 7, 2007 (edited) dont want ANY filler on the car cos i dont want it to look a messFiller pretty much always cracks, and black paint doesnt ever seem to set right on filler... Always looks Orange Peal. Edited April 7, 2007 by nfbr Quote Link to comment Share on other sites More sharing options...
paulbin Posted April 7, 2007 Report Share Posted April 7, 2007 filler doesnt crack if its been done properly. If the dent was pulled out properly and levelled with a panel hammer then it would only need a few skims of filler to fix, and black paint not sitting right on filler? orange peel is only ever in the clear top coat which can be flatted to look like glass. Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 7, 2007 Author Report Share Posted April 7, 2007 I'm probably just paranoid about the black paint thing as i've never seen a black car repaired that doesnt look like ass.. Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 7, 2007 Author Report Share Posted April 7, 2007 border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> Quote Link to comment Share on other sites More sharing options...
Jake-VW Posted April 8, 2007 Report Share Posted April 8, 2007 Same things happened to my car. Hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
lupo_1.0 Posted April 8, 2007 Report Share Posted April 8, 2007 (edited) that can be done mate no probs. and if you didnt want any filler then you will be looking at a whole side of the car not just a rear 1/4 as you will have to get the whole sill and the whole piller from front wing. just seems to be a lot more work then needed with the spraying on top of all that too.but that dent can be palled out, also the line above, maybe then tapped out then a thin skim of filler and then apply the stonechip again,(iam not a panel beater so may have missed a few things lol)and like paulbin said the orange peal is down to the paint side of things but can be sorted out anyway. Edited April 8, 2007 by lupo_1.0 Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 9, 2007 Author Report Share Posted April 9, 2007 and if you didnt want any filler then you will be looking at a whole side of the car not just a rear 1/4 as you will have to get the whole sill and the whole piller from front wing.My Hadrian Panels catalogue seems to say otherwise. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted April 9, 2007 Report Share Posted April 9, 2007 i'd rather have filler than a hadrians panel or any other pattern part for that matter, that dent will push forward from inside i have seen whole sides repaired that have been a 100 times worse than that using filler, your panick is ott you'll never know it was there, where as if the car had a quarter on it if you know what your looking for you'll find it, if i view a car i pull off the door shut rubbers to see what the spot welds are like and also remove a rear panel to see if the panels inside is in transport primer or the factoryy stuff, for a dent that size mate i'd have filler all day.hadrians panel £65 vw genuine £170 Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 9, 2007 Author Report Share Posted April 9, 2007 hmmYou make a good point...I've Tried to get into where the damage is from behind the door panel and its near on impossible... I lose my entire arm down the side before i can even touch the damaged area, never mind use any force on it.I'm pretty sure one of thems Suction/Slide hammer things should be able to pull the majority of it back into shape! Then it'd only need a light skim over with filler, as the main area of where its pysically bent the surface is on the hammered bit of the sill... Quote Link to comment Share on other sites More sharing options...
paulbin Posted April 9, 2007 Report Share Posted April 9, 2007 come down at the weekend leave it with me and i shall sort u out, shall i talk to my boss next this week? Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 9, 2007 Author Report Share Posted April 9, 2007 Can't afford it done yet mate style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> Need the car for the Volksdevil Doobyflop Quote Link to comment Share on other sites More sharing options...
lupo_1.0 Posted April 9, 2007 Report Share Posted April 9, 2007 My Hadrian Panels catalogue seems to say otherwise.but the rear panel is welded to just behide thelight, the to the roof and that panel follows the roof all the way down to the front wing, it is then welded under the door rubbers all the way around, and then the sill in also art of the rear 1/4.the rear 1/4 is that whole red thing, so it would be easyer to just cut it in places and not replace all of that. border="0" class="linked-image" /> border="0" class="linked-image" /> Quote Link to comment Share on other sites More sharing options...
Mitchell Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) cut at bottom b post and rear of quarter window to roof then only small areas to prep n repairstill a bit drastic imho Edited April 9, 2007 by mitch unit 21 Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 9, 2007 Author Report Share Posted April 9, 2007 (edited) Yup definately drastic for whats goosed...Also- Is that sprout sporting one of those new Pebble Dashed numberplates? Edited April 9, 2007 by nfbr Quote Link to comment Share on other sites More sharing options...
Unheard Posted April 9, 2007 Report Share Posted April 9, 2007 I'm pretty sure one of thems Suction/Slide hammer things should be able to pull the majority of it back into shape! Then it'd only need a light skim over with filler, as the main area of where its pysically bent the surface is on the hammered bit of the sill...hmmm just me thinking out loud but have you thought about side skirts if you could get most of it pulled out then side skirts would cover the main damage. some of the skirts look really subtle its just an idea!!! Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 9, 2007 Author Report Share Posted April 9, 2007 hmmm just me thinking out loud but have you thought about side skirts if you could get most of it pulled out then side skirts would cover the main damage. some of the skirts look really subtle its just an idea!!!I can see where your coming from as an inexperienced first time modder... but i'd sooner hang myself than tigerseal random bits of fibreglass to my car style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Unheard Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) as an inexperienced first time modder...no need for that mate!! Only thing that is different on my sport are the alloys, standard ones were kerbed to **** when I got the carthe exhaust got a custom built cat back no way i was paying £800 for the standard replacement when i could get a 304 stainless one with a lifetime guaranteeand a stubby aerial because I don’t like my car looking like its radio controlled, only other thing i intend to do is may be lower the car as it really could do with it and may be remove the bump strip as some nice person has already done part of the passenger side for me style="vertical-align:middle" emoid=":angry:" border="0" alt="mad.gif" />apart form that its staying 100% standardso ya that makes me an inexperienced first time modder style="vertical-align:middle" emoid=":clap:" border="0" alt="clap.gif" /> !! im not one for body kits and stick on bits but it was a potential solution to your problem and as I said just an idea Edited April 9, 2007 by Unheard Quote Link to comment Share on other sites More sharing options...
nfbr Posted April 10, 2007 Author Report Share Posted April 10, 2007 so ya that makes me an inexperienced first time modder style="vertical-align:middle" emoid=":clap:" border="0" alt="clap.gif" /> !! im not one for body kits and stick on bits but it was a potential solution to your problem and as I said just an ideaNo offence meant by it mate, but it just seems like a typical "Revs" "MaxPower" "Fast Car" answer to a problem, that doesnt really solve anything at all... Quote Link to comment Share on other sites More sharing options...
noddy Posted April 10, 2007 Report Share Posted April 10, 2007 I can see where your coming from as an inexperienced first time modder... but i'd sooner hang myself than tigerseal random bits of fibreglass to my car style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />this is why we love ya al style="vertical-align:middle" emoid=":shades:" border="0" alt="shades.gif" /> Quote Link to comment Share on other sites More sharing options...
lupo_1.0 Posted April 10, 2007 Report Share Posted April 10, 2007 no need for that mate!! Only thing that is different on my sport are the alloys, standard ones were kerbed to **** when I got the carthe exhaust got a custom built cat back no way i was paying £800 for the standard replacement when i could get a 304 stainless one with a lifetime guaranteeand a stubby aerial because I don’t like my car looking like its radio controlled, only other thing i intend to do is may be lower the car as it really could do with it and may be remove the bump strip as some nice person has already done part of the passenger side for me style="vertical-align:middle" emoid=":angry:" border="0" alt="mad.gif" />apart form that its staying 100% standardso ya that makes me an inexperienced first time modder style="vertical-align:middle" emoid=":clap:" border="0" alt="clap.gif" /> !! im not one for body kits and stick on bits but it was a potential solution to your problem and as I said just an ideamate your mods dont have to be justified to anyone on here. if ya like your car then thats all that matters, and if that makes you inexperienced then so be it. Quote Link to comment Share on other sites More sharing options...
airwolf Posted April 10, 2007 Report Share Posted April 10, 2007 (edited) mate your mods dont have to be justified to anyone on here. if ya like your car then thats all that matters, and if that makes you inexperienced then so be it.just regarding body kits on lupos i have side skirts and front bumper and some light brows on mine and soon escort gti alloys i like to be diffrent cant stand seein all lupos looking the same weres the fun in that and yes may sound bit max power ish but who cares just thought ad stick my nose in style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> Edited April 10, 2007 by airwolf Quote Link to comment Share on other sites More sharing options...
