Dcwd Posted April 25, 2022 Report Share Posted April 25, 2022 Want to swap engines from a 1.0 mpi to a 1.4 16v engine code for my engine is aub and the 1.4 is ahw will my gear box fit and is there anything else I need to change Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 25, 2022 Report Share Posted April 25, 2022 It'll be cheaper to buy a different car. Lots of work. Lots to change. Quote Link to comment Share on other sites More sharing options...
Dcwd Posted April 26, 2022 Author Report Share Posted April 26, 2022 What do you need ti change Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 26, 2022 Report Share Posted April 26, 2022 Everything that's different. Have a look at online manuals, engine bay pics, wiring diagrams etc... Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted April 26, 2022 Report Share Posted April 26, 2022 You will need whats called "full swap" - engine, wiring, gearbox, all pipes, ecu. Not as hard as turbo swap, but it takes nerve to swap to another engine. I just removed my engine by just lifting engine and gearbox with jack and holding them with hands. Quote Link to comment Share on other sites More sharing options...
Stephenmacleod Posted April 27, 2022 Report Share Posted April 27, 2022 you'll probably be best with a donor car. but you've got to weigh up the pro's and cons for it really, cost of a donor car (maybe 3-400 at a push if you find a rough one, then all the effort of swapping it over, then the need for modified insurance (plenty of companies about, greenlight, brentacre, adrian flux etc) whereas you might just be easier buying a 1.4 in the first place. Would be understandable if you wanted to go for a 6n2 GTi engine swap or a lupo gti motor swap, or even 1.8T (with a hell of a lot more work involved) as they didn't do a non GTi with the 1.6 and certainly didn't do a 1.8T, but IMO it just isn't worth doing a 1.0 to a 1.4. 1 Quote Link to comment Share on other sites More sharing options...
Stephenmacleod Posted April 27, 2022 Report Share Posted April 27, 2022 Also if your gearbox does fit (which i suspect it would but not 100%) a 1l gearbox you'd have decent acceleration but you'd have absolutely no top end, you'll just blow your box to bits if you give it some welly. 1 Quote Link to comment Share on other sites More sharing options...
DAN@ADRIAN FLUX Posted April 30, 2022 Report Share Posted April 30, 2022 Hi. If you have any issues with insurance for a change of engine then please feel free to drop me a line. Regards, Dan. 1 Quote Link to comment Share on other sites More sharing options...
stator Posted May 4, 2022 Report Share Posted May 4, 2022 On 4/25/2022 at 10:24 PM, Dcwd said: Want to swap engines from a 1.0 mpi to a 1.4 16v engine code for my engine is aub and the 1.4 is ahw will my gear box fit and is there anything else I need to change AUB is the 1.4v 16v 100HP Sport engine AHW is also 1.4 Where does the 1.0 come in? Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted May 5, 2022 Report Share Posted May 5, 2022 12 hours ago, stator said: AUB is the 1.4v 16v 100HP Sport engine AHW is also 1.4 Where does the 1.0 come in? I think he has AUC. Quote Link to comment Share on other sites More sharing options...
