Matt-Mk2
Parking lights not going off
howdy folks
The parking light on the drivers side will not go off, the indicator stalk is in the in the correct position,
Any ideas ?
can you make the other side go on? does the drivers side switch off? do the indicators work as normal? do you have an after market remote central locking thing, which activates the indicator lights?
Edited by mk2
Drivers side goes off when changing over to the passangers side,  but rear light on drivers side stays on
indicators working fine,
standard immo and RCL
thought the initial problem was down to the led bulbs i put in the side lights,
rear drivers parking light still on ,
took the bulb out, and changed it to see if it made a difference - no change,
driving me potty lol
Rear light "always" on, all the time? As in, you can't ever turn it off? Wierd.
Yup only goes off when I disconnect battery, side light on drives side stays on aswel with it
Narrowed the issue down to the light switch, ordered a new one to see if it makes a difference
I'm curious to know if that fixes it. Never ever heard of any vdub (seat) ever doing that. Indicator related failures- loads. Never a light switch that keeps one side of the car's sidelights on. Plain wierd.
Pull the fuse.
Could it be a faulty indicator, even when the stalk is centred,  keeping the parking lights on?
New switch solved the problem , stripped down the old one and a few of the resistor literally fell off
Can you post a pic of what you think failed... curious to know what caused it.
Also there was an open short on the switch itself
Hmm. A 620 ohm resistor... I think that is there just to dimly power the led lamp inside the switch.
Pleased you have sorted it anyway. If the same problem ever turns up ever again, we know how to deal with it now :)
Mainly alot of swearing and scratches heads and many many searches for wiring diagrams
LOL! Yeah. Been there done that... Especially engine looms.
But is is surprising easy to pull out a vdub light switch when you know how (push the switch in and turn to the centre, then just pull it straight out). Handy if you need a low power 12V feed to power something like a dash cam, only when the ignition is on- and you can feed the wire straight up the A pillar with minimal effort from there :)
