GeoScars Posted June 18, 2014 Report Share Posted June 18, 2014 I have a water leak but I have no way of knowing where atm anyone got any ideas on how to find out before it gets worse Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 19, 2014 Report Share Posted June 19, 2014 I have a water leak but I have no way of knowing where atm anyone got any ideas on how to find out before it gets worseNeither do we if you just say well my cars leaking water but I won't tell us where i.e. under the seat, under the engine etc etc. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 Well the expansion tank slowly gets lower and lower, I've checked hoses, engine cap for Mayo, radiator and still I'm none the wiser as to where its going Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 Well it must be going somewhere dude. It won't just evaporate, you will surely find a spot under your car? I'd be tempted drain the coolant, bang a can of radweld + water in, drive it for a few hours, drain again, put coolant back in, forget about it. Quote Link to comment Share on other sites More sharing options...
Mr.Badbrains Posted June 19, 2014 Report Share Posted June 19, 2014 Heater core? Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 19, 2014 Report Share Posted June 19, 2014 When ever you see the poddkd or trace the leak smell it. That way you can see if it if is coolant, washer fluid or water just stuck from rain. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 The only bit of water I've seen is under the front of the car and it was a little spot I wasnt to worried so I have no idea plus I can't get my cap off to fill it up and see if it leaks and follow it back Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 The only bit of water I've seen is under the front of the car and it was a little spot I wasnt to worried so I have no idea plus I can't get my cap off to fill it up and see if it leaks and follow it backYou can't get your coolant expansion tank cap off? Put some man effort in!!! They get hot and seize, but they're plastic, no rust. GET ON IT! Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 I'm on it! also Ill get back to you guys! thank you all for the help you give me Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 Radweld. Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 19, 2014 Report Share Posted June 19, 2014 You can put a screwdriver on the top help with leverage. Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 You can put a screwdriver on the top help with leverage.Then radweld Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 19, 2014 Report Share Posted June 19, 2014 Egg lol. Can't believe some people do that. Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 Egg lol. Can't believe some people do that. egg, mustard seeds, pepper, anything that is water insoluble. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 I did an it broke a bit off the cap Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 Did you get it off Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 Nope I didn't it won't budge Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2014 Report Share Posted June 19, 2014 Hmm, next way would be a hair dryer maybe? You may have to break it off so you could do with buying a new cap. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 19, 2014 Author Report Share Posted June 19, 2014 I will do haha just gotta get it off Quote Link to comment Share on other sites More sharing options...
matt123roll Posted June 19, 2014 Report Share Posted June 19, 2014 A set of moleys and some force removed the stubborn cap, done it loads Quote Link to comment Share on other sites More sharing options...
GeoScars Posted June 20, 2014 Author Report Share Posted June 20, 2014 Thank you;!!!!!! Quote Link to comment Share on other sites More sharing options...
