LUpo_bOy Posted March 3, 2014 Report Share Posted March 3, 2014 Just wondered if anyone knows how to dehandle a door, ive looked on the internet but cant find anything Quote Link to comment Share on other sites More sharing options...
Skezza Posted March 3, 2014 Report Share Posted March 3, 2014 You mean delock or smoothed? Quote Link to comment Share on other sites More sharing options...
LUpo_bOy Posted March 3, 2014 Author Report Share Posted March 3, 2014 I mean taking the handle off of the out side so its a smooth panel Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted March 3, 2014 Report Share Posted March 3, 2014 It will fail an MOT as you need to be able to get into the car from the outside using some sort of handleDoorsThe MOT tester will check all doors to make sure:•Both front doors are open able from the inside and out and that all doors latch securely in a closed position•Rear doors should open from the outside of the vehicle•All door hinges, catches and pillars to be assessed for opening and closing of the doors securely Quote Link to comment Share on other sites More sharing options...
stator Posted March 4, 2014 Report Share Posted March 4, 2014 How would you get in? The tailgate Quote Link to comment Share on other sites More sharing options...
Skezza Posted March 4, 2014 Report Share Posted March 4, 2014 I guess a door popper... I cringed slightly when I said that. Quote Link to comment Share on other sites More sharing options...
Karl_Mac_ Posted March 4, 2014 Report Share Posted March 4, 2014 (edited) I had smoothed doors on my Polo. It was an effing nightmare. Weld a panel over the recess for the handle, then add a solenoid to open the door, I had my button under the wing mirror. Its great until your battery goes flat. If you want to smooth out the sides get some Audi 80 door handles instead. Its a bitch of a job though. Edited March 4, 2014 by Karl_Mac_ Quote Link to comment Share on other sites More sharing options...
red_gnome69 Posted March 4, 2014 Report Share Posted March 4, 2014 I heard that TVR owners also have this issue as they have the door popper under the mirror. Solution is to leave the window open for the mot then they can lean in and open the door........Also leave a rear number plate light cover loose so you can always back feed a voltage through where the bulb was, again a bit unsure if this would actually work so please dont shoot me down in flames :S Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted March 4, 2014 Report Share Posted March 4, 2014 TVR Cerbera's have the door popper button mounted on the mirror, great when it works, nightmare if you get a flat battery! Quote Link to comment Share on other sites More sharing options...
