Rickpercy87 8 Posted August 19, 2013 Report Share Posted August 19, 2013 I'm running a remap at the moment, and wondering if a cold air feed would increase power? I understand in theory it should increase power, but do they really work? Particularly on remapped diesels? 1 Quote Link to post Share on other sites
RS6plusMTM 11 Posted August 19, 2013 Report Share Posted August 19, 2013 Not a massive amount, I understand the turbo is the crux of the 1.4 tdi as it runs out of puff long before you need to add cold feed or charge cooling/larger intercooler for more bhp Quote Link to post Share on other sites
Rickpercy87 8 Posted August 20, 2013 Author Report Share Posted August 20, 2013 Cheers, mate Quote Link to post Share on other sites
richardn 8 Posted September 5, 2013 Report Share Posted September 5, 2013 I've got a darkside developments intercooler on mine and its huge,really does a good job though and will drop the intake temp by around 40 degrees,mine was backing off power when the intake got to 66 degrees,now stays around the 25-30 even in the hot weather we have had,but yes the turbo is the main restriction Hope this helps Quote Link to post Share on other sites
Dblock 155 Posted September 5, 2013 Report Share Posted September 5, 2013 I've got a darkside developments intercooler on mine and its huge,really does a good job though and will drop the intake temp by around 40 degrees,mine was backing off power when the intake got to 66 degrees,now stays around the 25-30 even in the hot weather we have had,but yes the turbo is the main restriction Hope this helpsDoes lag and other issues not make it slower to boost? Also I read but I take with a pinch of salt a bigger intercooler could cost you power. Quote Link to post Share on other sites
richardn 8 Posted September 5, 2013 Report Share Posted September 5, 2013 Power stayed roughly the one with only a 1.4hp gain on dyne run,but torque was up by around 25-30 lb ft,tbh the lag is no different to how it was before Quote Link to post Share on other sites
Dblock 155 Posted September 5, 2013 Report Share Posted September 5, 2013 Nice! Quote Link to post Share on other sites
Karl_Mac_ 53 Posted September 5, 2013 Report Share Posted September 5, 2013 I don't think a cold air feed would make much difference. Getting more air in (so a larger filter or larger bore intake pipe) would be more beneficial as it'll be cooled by the I/C Quote Link to post Share on other sites
nfbr 119 Posted September 5, 2013 Report Share Posted September 5, 2013 When I had mine, I removed the intercooler and cleaned it out with IPA. It seemed to perform better afterwards! Quote Link to post Share on other sites
Dblock 155 Posted September 5, 2013 Report Share Posted September 5, 2013 I don't think a cold air feed would make much difference. Getting more air in (so a larger filter or larger bore intake pipe) would be more beneficial as it'll be cooled by the I/CI don't think thats possible. Have you seen the size of the filter. It is huge. I've got a darkside developments intercooler on mine and its huge,really does a good job though and will drop the intake temp by around 40 degrees,mine was backing off power when the intake got to 66 degrees,now stays around the 25-30 even in the hot weather we have had,but yes the turbo is the main restriction Hope this helpsWhich one did you get mate? E.g. size etc. Thanks Quote Link to post Share on other sites
loepan 34 Posted September 6, 2013 Report Share Posted September 6, 2013 don't know whether its possible on the lupo, but to combat problems with hot air,on other tdi's ive heard of leaving the existing piping to the air box, take the internal part of the airbox out including filter, extend the plastic tubing to inside the air box housing with a cone filter on the end of that, then drill air box base or wherever the cold feed is best.seems a lot of flaff tho' Quote Link to post Share on other sites
richardn 8 Posted September 13, 2013 Report Share Posted September 13, 2013 I don't think thats possible. Have you seen the size of the filter. It is huge. Which one did you get mate? E.g. size etc. Thanks Hi only just saw this ,I'll try and get a pic up Quote Link to post Share on other sites
richardn 8 Posted September 13, 2013 Report Share Posted September 13, 2013 1 Quote Link to post Share on other sites
