Carlowcaddy Posted February 16, 2013 Report Share Posted February 16, 2013 Hey guys .... With my 1ltr loop lacking a lot in the power dept running on standard steels I'm wondering if I am going to completely kill it by putting some 15in teledials on it . is it possibly gonna end up meaning ill be putting bushes and cv's into it on the regular ?? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 16, 2013 Report Share Posted February 16, 2013 Why would putting 15's on knacker the bushes and cv joints? Quote Link to comment Share on other sites More sharing options...
Carlowcaddy Posted February 16, 2013 Author Report Share Posted February 16, 2013 The extra unsprung weight of the wheels and tires themselves , more pressure on the likes of the cv joints to turn a larger diameter wheel with extra traction due to the road contact of a wider tire ?? Maybe, that's what I am asking you . Quote Link to comment Share on other sites More sharing options...
matt123roll Posted February 17, 2013 Report Share Posted February 17, 2013 No. Quote Link to comment Share on other sites More sharing options...
Carlowcaddy Posted February 17, 2013 Author Report Share Posted February 17, 2013 So your saying the bigger wheels ain't gonna effect the power of the car ? Quote Link to comment Share on other sites More sharing options...
marcyd Posted February 17, 2013 Report Share Posted February 17, 2013 I'm sure it affects the racio of the speed for eg. I had 13s on my 1l I put 15 inch alloys on and found I had less top end or is this just me ? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 17, 2013 Report Share Posted February 17, 2013 Well you would get lower profile tyres to match the rolling radius so no. Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted February 17, 2013 Report Share Posted February 17, 2013 If you get the correct tyres, the rolling radius won't be affected.Alloy wheels should weigh less than steel wheels. My 15inch Rotas + tyres are slightly lighter than my 13inch steel wheels + tyres.You might be putting more stress on some parts with the increased grip but, you're not going to be killing drive train bits very often. Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 17, 2013 Report Share Posted February 17, 2013 Buy the correct tyres and you'll have no issues.Play here to find what suits: http://www.miata.net/garage/tirecalc.html Quote Link to comment Share on other sites More sharing options...
harreeeee Posted February 17, 2013 Report Share Posted February 17, 2013 And do you not have to recalibrate the speedometer when you install larger diameter wheels? 1 Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 17, 2013 Report Share Posted February 17, 2013 No, you buy low profile tyres to match the rolling radius of the ones you are taking off.Standard sizes for Lupos are155\70\13185\55\14205\45\15195\45\15 are the ost common tyres fro 15" rims on a Lupo and will keep the speedo near to correct.Look at the link I posted. Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted February 17, 2013 Report Share Posted February 17, 2013 And do you not have to recalibrate the speedometer when you install larger diameter wheels?Google rolling radius. Quote Link to comment Share on other sites More sharing options...
Carlowcaddy Posted February 18, 2013 Author Report Share Posted February 18, 2013 Thanks for the heads up on rolling radius and speedo , it wasn't something that came to mind :-) ! Quote Link to comment Share on other sites More sharing options...
harreeeee Posted February 18, 2013 Report Share Posted February 18, 2013 (edited) No, you buy low profile tyres to match the rolling radius of the ones you are taking off.Standard sizes for Lupos are155\70\13185\55\14205\45\15195\45\15 are the ost common tyres fro 15" rims on a Lupo and will keep the speedo near to correct.Look at the link I posted.But when you compare those standard tyre sizes on the link you posted, it says there is a difference in rolling radius, so wouldnt speedo calibration be required? Edited February 18, 2013 by harreeeee Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 18, 2013 Report Share Posted February 18, 2013 On the standard "out of the factory car", the speedo will be calibrated to suit the size of wheel and tyre fitted to the standard car. It's not enough to worry about; so long as you don't go stupid. For breaking efficiency you should not really go over a certain % if putting larger sidewalled tyres on. You buy a new tyre with 8mm of chunky tread. When it past it's best and ready for the bin (@1.5mm) it will have lost about 6.5mm of that tread. That will reduce the diameter of the tyre by a whopping 13mm. Tell me that's not going to effect your speedo. My GTI will generally come into my drive without touching. When the tyres are old and ready for replacement, the exhaust catches. Go figure. Quote Link to comment Share on other sites More sharing options...
booble Posted February 18, 2013 Report Share Posted February 18, 2013 Sorry for hijacking your thread, but as its related, I'm swapping some 13 inch wheels with tyres 175/65 for 15 inch wheels with 195/50 tyres on. Will these be ok? on the rolling radius they appear similar to what's on now. I don't really want to go replacing the tyres yet as they have plenty of tread. Quote Link to comment Share on other sites More sharing options...
Karl_Mac_ Posted February 18, 2013 Report Share Posted February 18, 2013 Bear in mind that due to the nature of suspension components, even when brand new out of the factory your speedo will over read by as much as ten percent.Its not an exact science, there will be some change in performance whwn changing wheels, but it will be barely noticable. Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 18, 2013 Report Share Posted February 18, 2013 Sorry for hijacking your thread, but as its related, I'm swapping some 13 inch wheels with tyres 175/65 for 15 inch wheels with 195/50 tyres on. Will these be ok? on the rolling radius they appear similar to what's on now. I don't really want to go replacing the tyres yet as they have plenty of tread.If you are going upto 15, then 195\45 is a better tyre option. The 50 profile is fine on a standard - standardish car, but will rub when you start to lower. It will obviously depend on the ET of the wheels too. Quote Link to comment Share on other sites More sharing options...
booble Posted February 18, 2013 Report Share Posted February 18, 2013 Cheers both Quote Link to comment Share on other sites More sharing options...
