manilasuperstar
rear break piston comes off! help,,
iam changing my rear pads on my lupo gti,,iam compressing the piston by turning kt but it wont go inside,i turn it th ogher way and it happened,,i placed it all over again ,,and still in wont go in,,what will i do,,,thanks
Undo and take the top of the brake reservoir first, it should push back the piston easily then.
i did that before i took th pads off,the problem is the piston is only halfway and i cant install the two pp roads.coz i don't have space..i keep rotating the piston but nothing happens,,
You are compressing and turning at the same time aren't you? they don't just rotate and wind in you have to compress and turn.
Exactly! You will need a windback tool or if you dont wana buy one, you can use some grips or big pliers to rurn it and some more big grips to compress the piston back into the caliper, it wont work otherwise...
it makes the job of pad changing much easier if you have the windback tool. there are some cheap ones available but make sure they do vw's the set i have does everything from himalayan yaks to woucestershire old spots so be careful that you make the right selection!! if you use grips indescriminately they will destroy your pistons, so be warned
Last time I had to do mine I used a pair of water pump pliers and a carpenters g clamp, it's all a out the improv.....
