bowers155 Posted August 1, 2012 Report Share Posted August 1, 2012 how have people pinned up there centre exits? mines a wee bit low and want it to sit ring up in the bumper again? Quote Link to comment Share on other sites More sharing options...
adam bmx Posted August 1, 2012 Report Share Posted August 1, 2012 i think its the pipe bending that cause's it , my original sport backbox sagged but a new stainless exhaust corrected this. could try new hangers though Quote Link to comment Share on other sites More sharing options...
bowers155 Posted August 1, 2012 Author Report Share Posted August 1, 2012 might just take the back box off and bend it then Quote Link to comment Share on other sites More sharing options...
adam bmx Posted August 1, 2012 Report Share Posted August 1, 2012 yeah that could work, do it to the pipe that comes out of the back box Quote Link to comment Share on other sites More sharing options...
Owen33 Posted August 3, 2012 Report Share Posted August 3, 2012 I've just had old bike break cable wrapped round and self tapped to the wheel well. Done this to friends sport and noticed nines missing heat shield... Just don't bolt it to heat shield and will stay Neat for ever:) Quote Link to comment Share on other sites More sharing options...
BEP51 Posted August 3, 2012 Report Share Posted August 3, 2012 Had this issue too:I drilled through the wheel well and heat shield, then hammerited over the fresh exposed metal, ran a long bolt thru and tightened a nut to fix it up firmly to the wheel well, then put a large jubilee clip round the exhaust pipes (with plumbers' heat mat between it and the metal to stop it vibrating and squeaking. then drilled a small hole through the jubilee clip, then tightened a nut above and below the jubilee clip to stop it moving around.It is quite a good solution as you can adjust the height along the bolt thread to get it just at the height that you want. You may notice after that the centrebox now vibrates at low revs, this will also need a tiny bit of heatmat between the two hanging brackets at the back of the box. You have to change the heatmat every six months or so, but the whole job is far cheaper than a new exhaust or getting the pipes readjusted.The bracket isnt visible from behind the car either so isnt notable.Dont have any pics, but will try to get some later. Quote Link to comment Share on other sites More sharing options...
Hakster Posted August 3, 2012 Report Share Posted August 3, 2012 Don't be doing all this bolting through the body of the car, this means the whole exhaust will be hanging off this one bolt and will cause problems... Just go to your local custom exhaust place, they will heat the pipes and bend them up a litlle, this is what I did on my GTiBeforeAfter Quote Link to comment Share on other sites More sharing options...
