Matty Boy Posted June 30, 2012 Report Share Posted June 30, 2012 Hi all I'm going to start my conversion soon just looking for some help on a few things. What gearbox should I use? I've been told not to use the one out of a seat ibiza? Also wiring will the internal loom need to be change or will it need a custom one? Quote Link to comment Share on other sites More sharing options...
grazo22 Posted July 4, 2012 Report Share Posted July 4, 2012 it think gearbox is an 02a or 02j but i can't remember.Wiring harness you could buy a donor car and just take the whole lot out and use those clocks.Otherwise you would have to get the new ecu demobilized to run with the lupo barrel. There is a company who can connect the 2 looms together from my recollection, look under thread "My 1.8t conversion" as it's mentioned in there.Custom drive shafts, custom exhaust and downpipe, custom engine mounts, custom front panel and piping for intercooler and rad. It's a huge job that I have been contemplating for a long time. I wouldn't start without a donor car (A3 1.8t sport) that's the best as it's cheap as chips and parts you don't need are worth a bit. I would also want at least £1500 cash on top of the donor to make sure I could get everything done correctly. Quote Link to comment Share on other sites More sharing options...
grazo22 Posted July 4, 2012 Report Share Posted July 4, 2012 sorry forgot to mention the gearlinkage is different, agu engine used cable throttle body, hydraylic clutch so modified pedal box also, would need to uprate brakes with carbon lorraine pads and high carbon discs or do a g60 conversion Quote Link to comment Share on other sites More sharing options...
Matty Boy Posted July 5, 2012 Author Report Share Posted July 5, 2012 That's great thanks for your help! I'm going with the o2a gearbox and a hydro clutch, also a electronic throttle body cause mine is already electric. Should be started in the next month or so Quote Link to comment Share on other sites More sharing options...
grantmax Posted July 10, 2012 Report Share Posted July 10, 2012 grazzo is right ....the company that did my loom are called ACR look them up on Facebook ... andy outhwaitwe is the man you want .. did a spot on job!I used 02j ... slightly stronger box .. but wont really matter I heard 02a's are just as good!good luck with it bro! ... ps .. i would have WAY more than £1500 to hand! Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted July 11, 2012 Report Share Posted July 11, 2012 I'm using an 02a from a mk3 TDI. It's a CTN code and has a lot longer ratio's than a CDA/DPA 02a. The 16v 02a will top out around 130mph, which equates to relatively high rpm motorway cruising.I worked out that i'll be doing 1800rpm at 80 and if i could pull it to the redline i'll be doing 180mph! haha! Quote Link to comment Share on other sites More sharing options...
Tomjw Posted July 13, 2012 Report Share Posted July 13, 2012 I want this conversion so bad! Theres sooooo much to do though and you need to know your stuff... (Which I dont LOL) Quote Link to comment Share on other sites More sharing options...
sinki106 Posted July 13, 2012 Report Share Posted July 13, 2012 i've started my 1.8t build, but i have hit a wall, i went down to my local vw dealership to get the weld in engine mount the boy there couldnt find what i was looking for so he gave my a copy of the parts for diagram and the part that i need is on the diagram but there is no number next to it so he said he couldnt order it grrrrrr!!! now i know people have used them so i was wondering does anyone have a part number.I have Andy's mobile number, i can pm you with itYou will be looking at around £400-£450 for your loom to modified Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted July 13, 2012 Report Share Posted July 13, 2012 I'm going to use Polo GTI 9N2 mounts for my conversion.With regards to loom, i'm using the standard management and just modding the T14a loom to fit the Lupo.if you're not confident in wiring it yourself, try Qpeng or RubJonny off 'ClubGti' Quote Link to comment Share on other sites More sharing options...
ONS Performance Posted July 25, 2012 Report Share Posted July 25, 2012 i've started my 1.8t build, but i have hit a wall, i went down to my local vw dealership to get the weld in engine mount the boy there couldnt find what i was looking for so he gave my a copy of the parts for diagram and the part that i need is on the diagram but there is no number next to it so he said he couldnt order it grrrrrr!!!now i know people have used them so i was wondering does anyone have a part number.I have Andy's mobile number, i can pm you with itYou will be looking at around £400-£450 for your loom to modifiedHave you ordered your loom yet?i will get you the part number for the mount tomorrow Quote Link to comment Share on other sites More sharing options...
ONS Performance Posted July 25, 2012 Report Share Posted July 25, 2012 (edited) Im using a cupra r engine and loom, cutting and joining the looms together. (need to finish this)o2j box 5 speedcupra r gear linkage (drill 2 new holes in the center tunnel)polo gti hubs and brake set up (when changing to disk you need lupo gti hand brake cables)golf mk4 mount weld in on drivers side. (you will need a disel engine mount other wise it will hit the chassis leg and the gearbox will not fit)custom back mount and gearbox mountexhaust (i will be making in house as i have a ben person exhaust tube bender, once the engine is running)drivers side drive shaft (mk4 golf long shaft hammer the out cv joint off and fit the lupo one) WILL NEED TO BE SHORTENEDpassenger side (mk4 again switch ends then you have to cut and shorten the shaft) NOTE DO NOT CUT IN THE CENTER do it near an end as there will be less force and wight when spinning basic engineering.Think iv covered most stuff Edited August 6, 2012 by ONS Performance Quote Link to comment Share on other sites More sharing options...
