PhiLupo Posted June 19, 2012 Report Share Posted June 19, 2012 Hey guys, does anyone know why my set of RXII's are way too tight to fit on the rear hubs please?Cheers Quote Link to comment Share on other sites More sharing options...
Koop Posted June 19, 2012 Report Share Posted June 19, 2012 There aren't spigot rings stuck on either the wheels or the hubs by any chance? They should be 57.1mm centre bore same as your loop, check for signs of corrosion on both too, my rear hubs are bit rusted & they're pretty stiff when putting wheels on/off - in which case a gentle sanding or scrub with a wire brush should sort em out. Quote Link to comment Share on other sites More sharing options...
Ashh Posted June 19, 2012 Report Share Posted June 19, 2012 If they have been resprayed then the centre bore has probably been sprayed too. Quote Link to comment Share on other sites More sharing options...
Koop Posted June 19, 2012 Report Share Posted June 19, 2012 ^good point! Quote Link to comment Share on other sites More sharing options...
PhiLupo Posted June 19, 2012 Author Report Share Posted June 19, 2012 Ash is a genius I'm thinking! And cheers I'll have a look after work what's the best thing to measure the bore of the wheel? Quote Link to comment Share on other sites More sharing options...
JoeA Posted June 19, 2012 Report Share Posted June 19, 2012 They'll go on, might need a quick sand/ scrub. Mine were the same, i just put the wheel on and tightened all the bolts gradually and in sequence. It soon went on, then, it'll be stuck on, so hit the inside of the wheel at the bottom with a mallet (don't damage the wheel, use a rubber one/ hit the tyre) whilst that corner is jacked up (again be careful) and the wheel should come off. it should go on and off a lot easier after that. Quote Link to comment Share on other sites More sharing options...
PhiLupo Posted June 19, 2012 Author Report Share Posted June 19, 2012 Cheers man and I'll have a go when I get some stuff to do it Quote Link to comment Share on other sites More sharing options...
Ashh Posted June 19, 2012 Report Share Posted June 19, 2012 They'll go on, might need a quick sand/ scrub. Mine were the same, i just put the wheel on and tightened all the bolts gradually and in sequence. It soon went on, then, it'll be stuck on, so hit the inside of the wheel at the bottom with a mallet (don't damage the wheel, use a rubber one/ hit the tyre) whilst that corner is jacked up (again be careful) and the wheel should come off. it should go on and off a lot easier after that.This. Or sand the paint off in the first place as it can be quite difficult to get them off after forcing them on, even with a mallet. Let us know dude Quote Link to comment Share on other sites More sharing options...
