Pippard 1.0 Posted March 3, 2012 Report Share Posted March 3, 2012 Basically would like to install a rcd 200 head unit in my lupo, what adaptors are needed and any pics ? Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 3, 2012 Report Share Posted March 3, 2012 You'll have to turn it on every hour or so as you have no canbus signal to tell it to stay on. Quote Link to comment Share on other sites More sharing options...
Pippard 1.0 Posted March 4, 2012 Author Report Share Posted March 4, 2012 (edited) You'll have to turn it on every hour or so as you have no canbus signal to tell it to stay on.thanks looks like i wil stick with my gamma unit Edited March 4, 2012 by Pippard 1.0 Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 4, 2012 Report Share Posted March 4, 2012 Mr ColinG ran one on his old GTI for a while and had tthis issue. I asked a local audio fitter (do all Audi work) and they said there was no workaround. OK if you're only doing short journeys. Quote Link to comment Share on other sites More sharing options...
JJ Werrett Posted March 6, 2012 Report Share Posted March 6, 2012 after it turns off after one hour can u just push the power button to pop it back on again or does it not turn on at all till ignition off and bk on?as even if u went on a 2 hour drive u only need to just push the button turn it back on again which you may lost odd second or two which i be happy with Quote Link to comment Share on other sites More sharing options...
James827 Posted March 7, 2012 Report Share Posted March 7, 2012 after it turns off after one hour can u just push the power button to pop it back on again or does it not turn on at all till ignition off and bk on?as even if u went on a 2 hour drive u only need to just push the button turn it back on again which you may lost odd second or two which i be happy withMy beta unit is not receiving an ignition or maybe Can-bus signal so i have to manually turn it on and off, its not to much of an issue and becomes almost like a routine. i'm meaning to take the car to an auto electrician but haven't had the time Quote Link to comment Share on other sites More sharing options...
Philplop Posted March 7, 2012 Report Share Posted March 7, 2012 Lupos aren't canbus. I believe the rcd200 just needs turning back on, don't think you need to restart the car. It's probably more an of annoyance than anything. Quote Link to comment Share on other sites More sharing options...
JJ Werrett Posted March 7, 2012 Report Share Posted March 7, 2012 (edited) ah may get one then if its only that one or two seconds a song gone to just pop it back on is fine Edited March 7, 2012 by JJ Werrett Quote Link to comment Share on other sites More sharing options...
Pippard 1.0 Posted March 8, 2012 Author Report Share Posted March 8, 2012 What connectors will you need then as they have a weird connector and what about the aerial cable as there isn't a slot in te back for the lupo ones Quote Link to comment Share on other sites More sharing options...
puggled Posted March 8, 2012 Report Share Posted March 8, 2012 There are canbus simulators on German ebay for £70 You need a Fakra adapter for aerial. Quote Link to comment Share on other sites More sharing options...
Samanferr10 Posted May 4, 2013 Report Share Posted May 4, 2013 http://www.dension.com/sites/default/files/car-compatibility/volkswagen-12-04-11.pdfApparently it is compatible ? Quote Link to comment Share on other sites More sharing options...
Silver! Posted May 4, 2013 Report Share Posted May 4, 2013 ^^ That refers to iPod adapters. Does it not? Quote Link to comment Share on other sites More sharing options...
