jazzblueloop:) Posted November 4, 2011 Report Share Posted November 4, 2011 i got a lupo sport and i have taken the rear adjusters out and it dont look that low, can anybody tell me the secret of lows as iv seen some low lupos on here thanks Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted November 4, 2011 Report Share Posted November 4, 2011 No springsLet air out of tyresFitment illusionCut springsNo suspension Quote Link to comment Share on other sites More sharing options...
jazzblueloop:) Posted November 4, 2011 Author Report Share Posted November 4, 2011 haha i dont fancy cutting springs but is there a set of rear springs that will make it low. 1 Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 4, 2011 Report Share Posted November 4, 2011 there are some FK rear springs that ar shorter i think .. let you go lower... or get some custom springs made up.. http://www.coilsprings.co.uk/lowering.htm Quote Link to comment Share on other sites More sharing options...
jazzblueloop:) Posted November 5, 2011 Author Report Share Posted November 5, 2011 cheers mate soo many lupos on here look sooo much lower than mine lol Quote Link to comment Share on other sites More sharing options...
north wales loop Posted November 5, 2011 Report Share Posted November 5, 2011 cut em and get shorter shocks Quote Link to comment Share on other sites More sharing options...
ministig Posted November 5, 2011 Report Share Posted November 5, 2011 Make sure the front is low enough first, don't want none of that French stance! Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 5, 2011 Report Share Posted November 5, 2011 dont cut springs! stupid idear Quote Link to comment Share on other sites More sharing options...
jazzblueloop:) Posted November 6, 2011 Author Report Share Posted November 6, 2011 the front goes sooo low but the rear dont and dw i wont be cutting springs lol Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 8, 2011 Report Share Posted November 8, 2011 yes everyone has the problem with the rears...you either need the FK shorted springs... or go to that place i linked... its 45 quid .. and they will re use ure spings but make them shorter... and still fit all the adjusters and all that! Quote Link to comment Share on other sites More sharing options...
Piers Posted November 8, 2011 Report Share Posted November 8, 2011 dont cut springs! stupid idearyou cant spell... fool! lolIdea dougie! text me dude Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 8, 2011 Report Share Posted November 8, 2011 haha thanks piers and Piers... its ' Douggie ' Quote Link to comment Share on other sites More sharing options...
Piers Posted November 8, 2011 Report Share Posted November 8, 2011 (edited) haha thanks piers and Piers... its ' Douggie ' PMSL!Get it right! its Peirs... Rich says so! and he knows everything! Edited November 8, 2011 by Piers Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 8, 2011 Report Share Posted November 8, 2011 haha is that how he spells your name? :? Quote Link to comment Share on other sites More sharing options...
Piers Posted November 10, 2011 Report Share Posted November 10, 2011 haha is that how he spells your name? :?yeah rick does.... Quote Link to comment Share on other sites More sharing options...
Douggie Posted November 11, 2011 Report Share Posted November 11, 2011 haha Rick! Quote Link to comment Share on other sites More sharing options...
niallod Posted November 17, 2011 Report Share Posted November 17, 2011 shocks from a vauxhall corsa b will cost about £20 and are alot shorter then either chop a coil or two off the spring or get them compressed is what i done when i ran static... worked a treat. Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted November 17, 2011 Report Share Posted November 17, 2011 shocks from a vauxhall corsa b will cost about £20 and are alot shorter then either chop a coil or two off the spring or get them compressed is what i done when i ran static... worked a treat.couldnt you not use corsa springs aswell aswell if the shocks are short then lowering springs must b eshorter aswell, ther aint too much difference in weight between a corsa and a lupo so spring rates wont differ too much id presume Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted November 17, 2011 Report Share Posted November 17, 2011 corsa springs are pig tailed both ends and are MUCH shorter! would be better just to chop chop chop! Quote Link to comment Share on other sites More sharing options...
north wales loop Posted November 18, 2011 Report Share Posted November 18, 2011 (edited) me and my bro are in the process of getting some custom ones made, will be shorter and a lot harder so we can run low without much travel = no rubbing!!! happy days. also looking into shorter shocks.if they are any good we will possibly be ordering a batch and possibly selling them on here. Edited November 18, 2011 by north wales loop Quote Link to comment Share on other sites More sharing options...
jazzblueloop:) Posted November 19, 2011 Author Report Share Posted November 19, 2011 thanks for all the help guys Quote Link to comment Share on other sites More sharing options...
jackCLD Posted November 22, 2011 Report Share Posted November 22, 2011 i've found a problem with going lower on the front because of the driveshalft clearance although its not knocked yet, has anyone had a problem with that? and ive got corsa coilover dampers lying around but they were so cheep is it worth using them???Cheers Quote Link to comment Share on other sites More sharing options...
niallod Posted November 23, 2011 Report Share Posted November 23, 2011 chasis notch. although you can run it sitting on the driveshaft and it will self notch.. to be this low though it will be about 90-100mm low.. only able to do this with helper sprangs out in front. Quote Link to comment Share on other sites More sharing options...
AJ Joyce Posted November 23, 2011 Report Share Posted November 23, 2011 What are the shortest rear shocks that will fit a lup? Quote Link to comment Share on other sites More sharing options...
