Correct way to de-badge!
beska133
Use a heat gun (or hairdryer) and heat the badges up a bit, then get a credit card and slide it behind the badges and slowly work them off. There'll be some gunk behing them so fire on some bug and tar remover to get rid of it.
P.s use an old credit card cos it'll probs get nackered with the heat =]
spot on guys, all sorted, started just after first post, and just finished, poured hot water over them, then used string to prise them off along with an old credit card, then picked most of the sticky black gunk off, then used a dab of petrol to take the rest off, finally dab of t-cut to remove the dirt and then polished it, looks spot on, just need to wait a few washes so the dirt fading wears away!
