Greg Thomson Posted December 14, 2010 Report Share Posted December 14, 2010 Recently got the car lowered , coilovers are as low as they can go at the front The wheels are 6.5jx15For some reason it only scrubs at one side if you really force it into bends Any help please ? Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted December 14, 2010 Report Share Posted December 14, 2010 On full lock? My wheels are 15x7 and scub on the right alot more than the left and its on the inside wheels arch.Do you know where your wheels rubs? Quote Link to comment Share on other sites More sharing options...
bobbo Posted December 14, 2010 Report Share Posted December 14, 2010 Your camber probably isnt quite perfectly matched Quote Link to comment Share on other sites More sharing options...
Bickerton Posted December 15, 2010 Report Share Posted December 15, 2010 What side? Quote Link to comment Share on other sites More sharing options...
Greg Thomson Posted December 16, 2010 Author Report Share Posted December 16, 2010 Left , so do I need to get the tracking done to sort the camber. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 16, 2010 Report Share Posted December 16, 2010 No, proper wheel alignment Quote Link to comment Share on other sites More sharing options...
Jowey Posted December 17, 2010 Report Share Posted December 17, 2010 Recently got the car lowered , coilovers are as low as they can go at the front The wheels are 6.5jx15For some reason it only scrubs at one side if you really force it into bends Any help please ?Sounds like you need your wheels re-allinging with the backs.Make sure the garage you take it to doesn't charge you for aligning the rear as there is no adjustment Quote Link to comment Share on other sites More sharing options...
bithmeister Posted December 17, 2010 Report Share Posted December 17, 2010 Are you sure its not one of the driveshaft'sthey get pretty close to the chassis on very lowered loops,think the drivers side can rub Quote Link to comment Share on other sites More sharing options...
leweylupo Posted December 18, 2010 Report Share Posted December 18, 2010 Recently got the car lowered , coilovers are as low as they can go at the front The wheels are 6.5jx15For some reason it only scrubs at one side if you really force it into bends Any help please ?Long shot but known this one to be the case is the et (offset) the same on both front alloys ? have known people with this before & turns out to be one of the wheels may have been replaced previously, same stud pattern width style etc but not same et ? weired but true Quote Link to comment Share on other sites More sharing options...
vpolo Posted December 19, 2010 Report Share Posted December 19, 2010 only costs me 40 quid for 4 wheel laser alinement :/ Quote Link to comment Share on other sites More sharing options...
m4tt Posted December 20, 2010 Report Share Posted December 20, 2010 Thought I had the same thing bud - went round bends and noticed rubbing noise when turning right (so the left side rubbing) turns out there's' a patch on my driveshaft where the surface (rust!) Has rubbed off. !elieved to be/informed that it was the plastic casing covering the alternator wiring - just tied it out the way.And as said - watch the shafts on the chassis, mine are about a fingers width from eachother and you have to watch potholes or you get a nasty bang! Quote Link to comment Share on other sites More sharing options...
