CPall Posted November 11, 2010 Report Share Posted November 11, 2010 Hii have an Arosa mk2 with lupo lights in the rear, the lights have two clear parts for the reverse lights but only one works. (the passenger side)Are they supposed to have two reverse lights and one isn't working or is there only supposed to be one?help would be appreciated pleaseChris Quote Link to comment Share on other sites More sharing options...
BEP51 Posted November 11, 2010 Report Share Posted November 11, 2010 Legally only one has to work, as many cars are built with only one reverse light, but on lupos both should illuminate.Either a fuse or a bulb will be needed. Quote Link to comment Share on other sites More sharing options...
Sully! Posted November 11, 2010 Report Share Posted November 11, 2010 now chris, its tobe... yeah the arosa loom has only 1 side reverse where as the lupo has 2, but is perfectly legal. Quote Link to comment Share on other sites More sharing options...
CPall Posted November 11, 2010 Author Report Share Posted November 11, 2010 Legally only one has to work, as many cars are built with only one reverse light, but on lupos both should illuminate.Either a fuse or a bulb will be needed.This will be the same for arosa's wont it? I heard off someone that you dont need a reverse light for MOTor is that just wrong? Quote Link to comment Share on other sites More sharing options...
BEP51 Posted November 11, 2010 Report Share Posted November 11, 2010 (edited) im not sure for the mot, i would assume u should have at least one, the wiring in an arosa should be identical to that in a lupo (edit: altho reading above, seems im wrong and the spanish didnt bother wiring a second), just go open the back panels and get the bulb out, i expect it will be all blacked inside or with a break in the filament....However just read my book and it seems that it isnt actually on the list of things to check on the mot, but as long as one works then no worries. Edited November 11, 2010 by BEP51 Quote Link to comment Share on other sites More sharing options...
CPall Posted November 11, 2010 Author Report Share Posted November 11, 2010 now chris, its tobe... yeah the arosa loom has only 1 side reverse where as the lupo has 2, but is perfectly legal.Ayee i heard that like just checking haha cheers mate.Thinking of tinting them so theyre all red im not sure for the mot, i would assume u should have at least one, the wiring in an arosa should be identical to that in a lupo (edit: altho reading above, seems im wrong and the spanish didnt bother wiring a second), just go open the back panels and get the bulb out, i expect it will be all blacked inside or with a break in the filament....However just read my book and it seems that it isnt actually on the list of things to check on the mot, but as long as one works then no worries.Ayee cheers for the help Yeahh iv got a friend who works for nissan and he says that you dont need any apparently, was just getting some other opinions.Cheers Quote Link to comment Share on other sites More sharing options...
1gear Posted November 11, 2010 Report Share Posted November 11, 2010 If it has standard Arosa Mk2 lights then it will have a fog light on one side, and the reverse light on the other.If you have Lupo lights on it then it wont have another reverse light on it because it was only designed with one on it. Quote Link to comment Share on other sites More sharing options...
chris c Posted November 11, 2010 Report Share Posted November 11, 2010 its easy to make a small loom and take it from the passenger side to the drivers side quite easy to make it look stock aswell it really bugged me having only 1 reverse light lol pm me if you want me to do a quick how to Quote Link to comment Share on other sites More sharing options...
CPall Posted November 12, 2010 Author Report Share Posted November 12, 2010 its easy to make a small loom and take it from the passenger side to the drivers side quite easy to make it look stock aswell it really bugged me having only 1 reverse light lol pm me if you want me to do a quick how toMy dad was on about doing that, but to save hassle i think i might just tint the clear bit red Quote Link to comment Share on other sites More sharing options...
Emz Posted November 12, 2010 Report Share Posted November 12, 2010 im not sure for the mot, i would assume u should have at least one, the wiring in an arosa should be identical to that in a lupo (edit: altho reading above, seems im wrong and the spanish didnt bother wiring a second), just go open the back panels and get the bulb out, i expect it will be all blacked inside or with a break in the filament....However just read my book and it seems that it isnt actually on the list of things to check on the mot, but as long as one works then no worries.The Arosa MK2 and the Lupo have different wiring, to fit Lupo rear lights onto an Arosa you have to re-wire this, as the MK2 real lights only have 1 reverse light, that would be by why when the Lupo rear lights are fitted there is only one reverse light, however as mentioned and can quite easily be wired so that there is 2 reverse lights. Quote Link to comment Share on other sites More sharing options...
Philplop Posted November 12, 2010 Report Share Posted November 12, 2010 Yeah, you don't need reverse lights. They are there as an aid so you can see behind you whilst driving, not to alert other people that you are reversing.They are not checked on an MOT at all, so you will pass with one reverse light, red reverse lights or no reverse lights at all. Quote Link to comment Share on other sites More sharing options...
CPall Posted November 12, 2010 Author Report Share Posted November 12, 2010 The Arosa MK2 and the Lupo have different wiring, to fit Lupo rear lights onto an Arosa you have to re-wire this, as the MK2 real lights only have 1 reverse light, that would be by why when the Lupo rear lights are fitted there is only one reverse light, however as mentioned and can quite easily be wired so that there is 2 reverse lights.Yeah, you don't need reverse lights. They are there as an aid so you can see behind you whilst driving, not to alert other people that you are reversing.They are not checked on an MOT at all, so you will pass with one reverse light, red reverse lights or no reverse lights at all.I'll be tinting them alllll red tommorow then check my thread for updates of when it happens Quote Link to comment Share on other sites More sharing options...
CPall Posted November 13, 2010 Author Report Share Posted November 13, 2010 Pics in members cars thread. link in my sig Quote Link to comment Share on other sites More sharing options...
