Golf+sezza Posted August 17, 2010 Report Share Posted August 17, 2010 Hello peeps,Does anyone know how to remove the centre console section where you have the windscreen vents then the central two vents with radio underneath.Also the side vents (passenger's and driver's) as I want to paint all of these sections.Fanks! Quote Link to comment Share on other sites More sharing options...
Mike_M Posted August 18, 2010 Report Share Posted August 18, 2010 Far left vent pulls out with leverageRight vent there are a couple of screws to remove underneath, then push the light switch knob in......twist to the right and pull to take that out and reveal a final screw.Central section needs you to remove the stereo. Once out there are several T20 screws and it should pop out with ease.The vents near the windscreen are plastic rivet welded, so you have to break/cut it from the dash then glue down when putting back Quote Link to comment Share on other sites More sharing options...
Golf+sezza Posted August 18, 2010 Author Report Share Posted August 18, 2010 Ahhhh many thanks, will have to be patient and delicate the day I tackle this one then! Quote Link to comment Share on other sites More sharing options...
forsh21 Posted August 18, 2010 Report Share Posted August 18, 2010 I didnt glue mine back in it seemed to clip back together, altho i'm getting bad rattling from around that area now needs checking out Quote Link to comment Share on other sites More sharing options...
Rudaz Posted August 23, 2010 Report Share Posted August 23, 2010 i too want to remove these parts for painting, but i already have a bad rattle coming from the blowers pointing to the windscreen! wondering if the clips may alreday be broken... needs checking out i think!! Quote Link to comment Share on other sites More sharing options...
