R99 Posted March 18, 2010 Report Share Posted March 18, 2010 (edited) Hi Guys,Right, I am new to the VW world having had two MINI's previous. So my questions might be really simple, apologies if they are! I have the possible opportunity to buy some BBS RM's with blue centres. They are 7.5" front & 8.5" rear. 15" 4x100. The seller doesn't know the ET, but he bought them from a Lupo GTI owner. Condition wise they are very good with no kerbing, and one small mark that you have to look for. The centre caps are included.He also has some Toyo Proxies (194/45?) that he took off the alloys when he bought them, which he would sell me with the BBS.He is after £800 posted, does that sound a good price?So basically I am just after some help from you guys, I have two main questions:1) What are they worth (with tyres & without)?2) Will they fit my GTI without having to do arch modification and/or causing the tyres to scrub? I ask this because I have AP coilovers waiting to go on, and I plan on reducing the ride height a fair bit too. Thanks in advance! Edited March 19, 2010 by R99 Quote Link to comment Share on other sites More sharing options...
gilybob Posted March 18, 2010 Report Share Posted March 18, 2010 that price is good if there in v good condition mate..im not sure on the second question im sure someone will help soon good luck.. put sum pics up when its all doneawsome Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 18, 2010 Report Share Posted March 18, 2010 From reading threads on here, i very much doubt you will be able to put them on with out arch work. From the little knowledge i have, most RM's start out in life at about 6.5" wide with an et of around 36.Adding 2 inchs the the outside of the wheel will make the et pretty low. The 195/45 tyres wont help either, you would need to run skinnier tyres i would imagen, out side on the limits the manufactuer recommends. People think that the lupo gti has wider archs than a normal lupo, it does, but it also has a wider track.... I have seen someone say once that they think you could get wider/lower et wheels on a non-gti Quote Link to comment Share on other sites More sharing options...
sheps Posted March 18, 2010 Report Share Posted March 18, 2010 These wont fit right if running low on these tyres without major arch work my mate has 8's on the back with same size tyres and they rub with arces rolled and adjusters in so unless you ran a dangerous stretch or got your arches properly pulled your not gonna get them to fit right. Maybe work ok on a 185/45 but thats still gonna be pushing it. Hope that helpsSam Quote Link to comment Share on other sites More sharing options...
bithmeister Posted March 18, 2010 Report Share Posted March 18, 2010 Im running 7" on the front and 7.5" on the rear,with 165/50/15 tyres its on coilovers with the rear adjusters removed,and ive rolled the rear arches,its perfect no rub what so everpersonally think 8" are to wide if its slammed,but its going to rub for england on 8.5"a nice compromise is 7" all round you can slam it it still drivableheres a pic Quote Link to comment Share on other sites More sharing options...
sheps Posted March 18, 2010 Report Share Posted March 18, 2010 (edited) Or 6.5" and space the back out a bit that way it's not got different stretch and can be nicely decked Edited March 18, 2010 by sheps Quote Link to comment Share on other sites More sharing options...
R99 Posted March 18, 2010 Author Report Share Posted March 18, 2010 Thanks guys I really don't want to be doing things like arch rolling.My other choice are TH Mono's which are starting to sound like a better option. Quote Link to comment Share on other sites More sharing options...
R99 Posted March 18, 2010 Author Report Share Posted March 18, 2010 TH Mono's are avaliable in 15x7I'm guessing there would be no fitament issues with those when dropped? I.E no arch work needed? Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 18, 2010 Report Share Posted March 18, 2010 Whats the ET on them? most important to know! Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 ET 32 Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 19, 2010 Report Share Posted March 19, 2010 They should fit fine i think, what size tyres?Someone else will confirm this i hope Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 (edited) Ok, I have another question about the TH MONO'sWill the following specs fit with the plans I have to lower?7J x 15100 PCDET40 Offset62mm centre holeSorry guys, but I'm a total noob when it comes to this! Edited March 19, 2010 by R99 Quote Link to comment Share on other sites More sharing options...
greenson Posted March 19, 2010 Report Share Posted March 19, 2010 they will fit mate, but the vw centre bore size is 57.1mm so you will need spiggot rings to make them fit/sit correctlybest sitting lupo Lee, and thats a fact! Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 Great news. Will they sit flush with the arches with an offset of 40?Are spigot rings easily found in the format I will need?Thanks for the help! Quote Link to comment Share on other sites More sharing options...
cafcross Posted March 19, 2010 Report Share Posted March 19, 2010 They make 7" Monos?! May need to get some as the 8a scrub my front arches. Quote Link to comment Share on other sites More sharing options...
Dazz Posted March 19, 2010 Report Share Posted March 19, 2010 (edited) They make 7" Monos?! May need to get some as the 8a scrub my front arches.I've never seen 7" mono's normally 8"!? Edited March 19, 2010 by Dazz Quote Link to comment Share on other sites More sharing options...
greenson Posted March 19, 2010 Report Share Posted March 19, 2010 Yeah they do make them, but it would look like your running different wheels, don't blend as well as different width bbs for example Quote Link to comment Share on other sites More sharing options...
greenson Posted March 19, 2010 Report Share Posted March 19, 2010 They make 7" Monos?! May need to get some as the 8a scrub my front arches.you need to swap the 195's to 185's to stop/reduce the rubbing mate Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 (edited) Well, they list 7" wide TH MONO's on the Dubmesiter website. These are the wheels I have bought, pick them up on Tuesday. They look the same as TH MONO, but they are branded with "COMPOMOTIVE" & "RALLYE" on them. 7J x 15100 PCDET40 Offset62mm centre holeThey need a refurb as they have gravel rash from their previous life as rally car wheels. I just need to decide on what colour to go with now (suggestions?!)Then get some tyres sorted, what size would be best? Edited March 19, 2010 by R99 Quote Link to comment Share on other sites More sharing options...
Philplop Posted March 19, 2010 Report Share Posted March 19, 2010 (edited) They're proper rally ones, surely white is the only option!Not sure how it would look against the grey paint though.195/45's, no need to stretch, they'll fit under your arches nicely. Edit: if not white, go for silver, IMO. Edited March 19, 2010 by Philplop Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 Also forgot to ask, where can I get some centre caps for them? Thanks! Quote Link to comment Share on other sites More sharing options...
Philplop Posted March 19, 2010 Report Share Posted March 19, 2010 www.comp.co.uk Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 Mint, thanks for that tip. Will ring them in the morning to find out exactly which ones I need. Hmm, I'm not sure if it could pull off white. I was thinking of maybe getting them done in anthracite, or silver is a potential option too. Should I get the lettering highlighted of just left minimal? Quote Link to comment Share on other sites More sharing options...
BaileyVW Posted March 19, 2010 Report Share Posted March 19, 2010 sweet comps tbf... would be nice to highlight the text i rekon but thats just my opinion lol.... sand em back and mirror polish ftw lol Quote Link to comment Share on other sites More sharing options...
R99 Posted March 19, 2010 Author Report Share Posted March 19, 2010 I'm pretty happy with them. I like the idea of the mirror polishing, but I'm guessing they will need lots of care and attention once they are done in order to prevent any corrosion etc?How much £££ would I be looking at for a mirror polish refurb? Quote Link to comment Share on other sites More sharing options...
