Project Snotbox - DEAD!
hodge112
yeah thatd be great
did you have 7s? hard to fit?
yea got 7s, ummm cut dwn the wobble bolts at the bk and run no spacers, front 3mm spacers to get past calipers. lol u must be crazy for me to take a pik in the snow!!! will do soon tho
  • Replies 295
  • Created
  • Last Reply
Top Posters In This Topic
yea they hit the brake shoes, wat tyres u running?? i got 165 55 13 little bit of stretch
ah thought so lol, ill bear that in mind when i get mine then
yeah im going to be running 165/55s too :)
yep with the wheels on it will be sweet! i want to see this l0o0o0o0o0ower tho :o:o:o:D
cheers
its ll the way down at the front and reducers out at the back, with the new wheels and tyres it should drop it a bit more too, the profile on the tyres atm is 65 :o
Logged in on my girlfriends account lol hodge112
Edited by xkarinx
cheers dude
really excited to put the wheels on now, gotta wait though :(
will be on for ultimate dubs, im on the vagwales clubstand so hope to see some of you there
bit of an update today...
took the sunroof out the other day to get the sunroof hatch thingy out for retrimming, took it all apart and sprayed the plastic bit black too, then put it back together today...
might get the headlining back in sometime lol
allso took the parcel shelf out today and gave it a quick coat of black paint...
still looks pretty grey in the picture but if you compare it to the seats.
probably do another coat or two anyway, and when iv got money itlle probably be done in suede too
let me know what you think :)
Thats what ive doen in mine.. but ive retrimmed it in suede.. i cant beleive the sunroof had to some out to get this out. its so so difficult to do the actual lining though and i want another now to just spray.. (instead of trying to suede it.) Looks like the spray comes out really well.
Finding a sunroof lupo's headlining though its solid!!
the headlining itself is done in suede, well just finishing off lol
ive only sprayed the parcel shelf for now, and ill see what fabrics left over, and do it eventually :)
but yeah the roof itslef is a bit of a bugger in places
random pictures from todays efforts lol
had the sunroof out to put the retrimmed hatch thingy back in, thank god it didnt rain lol
(dont think i could have got more cars in the picture if id tried lol)
and thought id put this up, makes the lupo look tiny i thought lol
small update today
got this cone filter from vpolo the other week, and got a silicone bend now so fitted it :)
before...
after...
ignore my engine bay atm, its full of dust and generally needing some attention and paint ;)
the filter makes a big difference, the car idles much nicer aswel as sound loads better :D, although i wanna make it black and not grey lol
im gonna get rid of the old pipework and get a cold air feed put in, got one sat in the garage already lol
thoughts?
cheers
well ordered some vinyl the other day off ebay...
planned on making my own camouflage in certain places on the car :twisted:
had a quick go and done the sunroof switch surround bit, thought id break up all the black plastic plus a bit different...
not 100% sure on it just yet, may add a bit more white and black to it, but didnt wanna go OTT
plus might spray the interior light too, not too sure tbh
What does everyone think??
cheers
bit more vinylinig today
done the engine cover...
before....
and now....
pretty happy with it
gonna do a bit more in the engine bay to tie it in better
cheers
cheers :)
yeah i like it but i dont want it to be too in your face if you like
the vinyl not too hard, the engine cover is a bit difficult because of the shape in places lol
it also a bit awkward because we had to cut the shapes out ourselves, to make the camo pattern
the engine was sprayed grey and the sunroof things was wrapped in vinyl
i couldnt fine any camo that i like in sheetsm or for a cheapish price either, this way probably easier though lol
cheers guys, thought id try it out lol, it was one of them im just gonna dfo it and see what happens lol
gonna carry it on a little bit but not over the top like ive said
cheers for the comments, must be doing somthing right lol
cheers dude :)
small update today, got this in the post :D
JBL GTO 75.2, won it on ebay for just under half the retail price so pretty happy with that
found this spec list on the web, should be right but not 100% sure
GTO 75.2 Specifications
Output Power: 97W RMS x 2 channels @ 4 ohms; ≤1% THD + N
(14.4V supply) 145W RMS x 2 channels @ 2 ohms; ≤1% THD + N
290W RMS x 1 channels @ 4 ohms; ≤1% THD + N
Signal-to-noise ratio: 82dBA (reference 1W into 4 ohms)
Dynamic power: 190W @ 2 ohms
Effective damping factor: 6.39 @ 4 ohms
Frequency response: 10Hz – 90kHz (–3dB)
Maximum input signal: 5.5V
Maximum sensitivity: 230mV
DC Offset <50mV (-50%)
Output regulation: .098dB @ 4 ohms
Idle Current 1.0A
Input Impedance 22kΩ
Max Current Draw 23A @ 4 ohms
37A @ 2 ohms
Dimensions: 11 5/8 x 12 5/16 x 2 3/8” (L x W x D)
(295mm x 313mm x 60mm)
Fuse: 30A
thought it had less power so cant complain
either way it will work for what i want :D
thoughts?
cheers
just picked this up off Vpolo :D
•Slim, compact 10" (25cm)shallow-mount subwoofer
•Maximum output power 1.000 Watt
•Nominal output power 250 Watt
•Frequency response 20 - 1000 Hz
•Sensitivity (1W/1m) 87 dB
•Woofer size (cm) 25 cm
•Woofer material Interlaced Glass/Carbon Fibre reinforced IMPP™ upper cone
•Recommended sealed enclosure (Litres) 17 litres
cheers
also rear badge is nearly finished too
one more coat of satin black to the VW bit and it can go back on
tried to make it a bit subtle think its work alright
thoughts?
cheers
wee update...
bear in mind its not finished
before...
during :roll: ....
now....
not fully finished atm
not too far away though :D
also just ordered my tyres for the alleycats too, get them fitted for UD now :heart:
thoughts?
cheers
been busy today...
had to customise a mates old floor to make my amp fit, also ripped the material off it :o
also sealed the sub box, to make it air tight, and then started to re-trim it
bear in mind most of it was just bare wood before this
look alright i think, will probably do the whole thing, the lid needs doing in black but at least its not just wood, but if theres time itll be done for UD too
also theese arrived today :heart:
random picture from the day
cheers
