Nicki Posted November 15, 2004 Report Share Posted November 15, 2004 I've found a rather tasty set of wheels, only problem is that they are 7x15 et 13 so would stick out about another inch...What do you guys reckon? Is it `do-able`? Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted November 15, 2004 Report Share Posted November 15, 2004 not sure. think it will stick out too much. And depends if it lowered. would look like a mini thats got no arches. The back would prob look ok but not the front. Quote Link to comment Share on other sites More sharing options...
Nicki Posted November 15, 2004 Author Report Share Posted November 15, 2004 Its not lowered... yet... was my plan to lower it `30-40mm` next year though... Quote Link to comment Share on other sites More sharing options...
chris260 Posted November 15, 2004 Report Share Posted November 15, 2004 I not so sure it would look good either, 13's or 14's look ok sticking out a bit IMO but i've not seen 15's on a lupo that stick out. I'm pretty sure you'd run into problems too if you wanted to lower it, i think you'd definately have to use coilovers Quote Link to comment Share on other sites More sharing options...
Nicki Posted November 15, 2004 Author Report Share Posted November 15, 2004 Yeah, the plan is to get fully adjustable coilovers... Quote Link to comment Share on other sites More sharing options...
Nicki Posted November 15, 2004 Author Report Share Posted November 15, 2004 What's the et on bathursts anyway? Quote Link to comment Share on other sites More sharing options...
chris260 Posted November 15, 2004 Report Share Posted November 15, 2004 Think it's 43 but don't quote me on that!! :wink: Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted November 15, 2004 Report Share Posted November 15, 2004 yeah tis 43 Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted November 15, 2004 Report Share Posted November 15, 2004 get some 30mm wheel spacers behind bathurst. You can then see how much they stick out. style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Nicki Posted November 15, 2004 Author Report Share Posted November 15, 2004 Cunning plan!If only Tris had his cabby at the moment - he's got 7x15s that are about et 15 I think... Quote Link to comment Share on other sites More sharing options...
willh Posted November 15, 2004 Report Share Posted November 15, 2004 Yeah agree with tshirt2k - you can pick up packs of shady spacers from Halfrauds for not much.Is it a Gti or not? Gti's have slightly wider arches by `5-10mm` i think, meaning wider wheels might be ok.`30-40mm` isn't a massive drop on a Loop, and if the correct tyres are used (195/45's or even thinner for that streeetched look!) you may be ok.My Sport comes with 185/55/14's (standard - Kylami) and I've dropped it substantially, and they only scrub occasionally. IMO you may struggle when dropped on a `non-Gti`, but a Gti may be able to squeeze them in even when lower. The only way to know for sure is to test with other wheel and spacer combos.Obviously tho if you're prepared to spend a bit on arch work then nearly any size is possible! Quote Link to comment Share on other sites More sharing options...
Nicki Posted November 15, 2004 Author Report Share Posted November 15, 2004 Yeah, I've got a GTi.It'll stick out another 36mm which is a bit too much I'm guessing & the centreline being different could make for some "interesting" handling...Ah well, was only an idea... Quote Link to comment Share on other sites More sharing options...
zaza Posted November 17, 2004 Report Share Posted November 17, 2004 QUOTE(nickilupo)I've found a rather tasty set of wheels, only problem is that they are 7x15 et 13 so would stick out about another inch...What do you guys reckon? Is it `do-able`?can u show me the pic!!i'm interestung in et 13 one Quote Link to comment Share on other sites More sharing options...
GTi Si Posted November 17, 2004 Report Share Posted November 17, 2004 Isn't the standard tyre size on the GTi 205/45/15?S Quote Link to comment Share on other sites More sharing options...
