bikemad04 Posted February 11, 2010 Report Share Posted February 11, 2010 You don't need VAG-COM, just look under the bonnet, on the headlamp there are 2 nylon adjuster screws, best do it on a beam alignment tool like the one at a MOT station.Adjusters in mine are broken, and in my spare one Thought you had to activate it in VAG COM before adjusting with these screws or you could damage the headlamps? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 11, 2010 Report Share Posted February 11, 2010 I adjusted mine quite a bit and they are still fine Quote Link to comment Share on other sites More sharing options...
Philplop Posted February 11, 2010 Report Share Posted February 11, 2010 You don't need VAG-COM, just look under the bonnet, on the headlamp there are 2 nylon adjuster screws, best do it on a beam alignment tool like the one at a MOT station.Adjusters in mine are broken, and in my spare one Thought you had to activate it in VAG COM before adjusting with these screws or you could damage the headlamps?That's what I heard too. Possibly why 99hjm's adjusters are broken? Previous owner could have adjusted them too much.When you put it on VAGCOM you set it into headlight adjust mode, then adjust it on the headlight, then save that setting. Quote Link to comment Share on other sites More sharing options...
bikemad04 Posted February 11, 2010 Report Share Posted February 11, 2010 That's what I heard too. Possibly why 99hjm's adjusters are broken? Previous owner could have adjusted them too much.When you put it on VAGCOM you set it into headlight adjust mode, then adjust it on the headlight, then save that setting.Yeh thats what I thought I need mine adjusting after the work I had on them so I am gonna make sure whoever adjusts them does it on VAG COM to avoid any problems sure someone could confirm this? Quote Link to comment Share on other sites More sharing options...
Toi gulp Posted February 11, 2010 Author Report Share Posted February 11, 2010 current ideas anyone, stay on topic? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 11, 2010 Report Share Posted February 11, 2010 Thought you had to activate it in VAG COM before adjusting with these screws or you could damage the headlamps?You do really.That's what I heard too. Possibly why 99hjm's adjusters are broken? Previous owner could have adjusted them too much.When you put it on VAGCOM you set it into headlight adjust mode, then adjust it on the headlight, then save that setting.No, it's because the PO must of had a car park crunch, the light shell has a crack inside it, the GTI lights are so fragile.Yeh thats what I thought I need mine adjusting after the work I had on them so I am gonna make sure whoever adjusts them does it on VAG COM to avoid any problems sure someone could confirm this?Yes, easy to do. They just need to follow the instructions from link on the other thread.current ideas anyone, stay on topic?Sorry. Will have alook on ELSA tomorrow. Quote Link to comment Share on other sites More sharing options...
