CopeyCupra Posted July 20, 2009 Report Share Posted July 20, 2009 would 4x100 - 5x100 pcd adapters, then 5x100-5x112 adapters fit my arosa?will it be safe? im goin to roll my arches so it doesnt bother me how much it sticks out. ill roll the arches to suit.any ideas? i want the dished look of the AMG wheels and maily to be diferent Quote Link to comment Share on other sites More sharing options...
cafcross Posted July 20, 2009 Report Share Posted July 20, 2009 In a word no.Best bet is changing the hubs for Mk3 Golf hubs. Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted July 20, 2009 Author Report Share Posted July 20, 2009 In a word no.Best bet is changing the hubs for Mk3 Golf hubs.would they fit? what about my abs? would i be able to get bigger brakes then and what will they to with my abs? Quote Link to comment Share on other sites More sharing options...
cafcross Posted July 20, 2009 Report Share Posted July 20, 2009 No idea about the ABS, but they will fit.The only other option is to have either your hubs or the wheels welded and re-drilled. Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted July 20, 2009 Author Report Share Posted July 20, 2009 No idea about the ABS, but they will fit.The only other option is to have either your hubs or the wheels welded and re-drilled.ive hard about that. how would they re drill my hubs as i have reaqr discs and the handbrake set up is in there isnt it? Quote Link to comment Share on other sites More sharing options...
cafcross Posted July 20, 2009 Report Share Posted July 20, 2009 Best bet is having the holes redrilled in the wheels then. Would be easier too as you wouldn't have to take the car apart etc.I wanted Merc wheels for my GTI and was faced with the same dilemma, but couldn't be bothered with the hassle. But if you want them that bad then go for it. Quote Link to comment Share on other sites More sharing options...
cobblers Posted July 20, 2009 Report Share Posted July 20, 2009 (edited) I looked into this and found Mk3 front hubs won't fit (On my small braked lupo), some rears will though. Look at mk5 polo rear hubs too. It's fine to use 2 piece adapters, but the thickness would push the wheels too far out, especially if you want to have a nicely dished wheel.You can redrill the 4x100 hub to 5x100 without having to weld the existing holes, then run 5x100 to 5x112 adapters, but it would be a pain in the arse really!There isn't room (diameter wise) to drill the hubs to a PCD bigger than 100mm, so you'll need adapters no matter what! Edited July 20, 2009 by cobblers Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted July 20, 2009 Author Report Share Posted July 20, 2009 I looked into this and found Mk3 front hubs won't fit (On my small braked lupo), some rears will though. Look at mk5 polo rear hubs too. It's fine to use 2 piece adapters, but the thickness would push the wheels too far out, especially if you want to have a nicely dished wheel.You can redrill the 4x100 hub to 5x100 without having to weld the existing holes, then run 5x100 to 5x112 adapters, but it would be a pain in the arse really!There isn't room (diameter wise) to drill the hubs to a PCD bigger than 100mm, so you'll need adapters no matter what!so if i can get my hubs drilled to 5x100 the pcd adapters to 5x112 it wouldnt stick out tht much and wouldnt be too much hassle.does any 1 know someone who drills hubs? Quote Link to comment Share on other sites More sharing options...
LiamD Posted July 20, 2009 Report Share Posted July 20, 2009 Or how about this crackingly simple idea - get some custom adaptors made to take it from 4x100 to 5x112 pcd?http://www.red9design.co.uk/wheeladaptors.htmDon't over-think things too much chaps Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted July 20, 2009 Author Report Share Posted July 20, 2009 Or how about this crackingly simple idea - get some custom adaptors made to take it from 4x100 to 5x112 pcd?http://www.red9design.co.uk/wheeladaptors.htmDon't over-think things too much chaps some bloke has done them but he discontinued them for some reason Quote Link to comment Share on other sites More sharing options...
cafcross Posted July 20, 2009 Report Share Posted July 20, 2009 That's not possible as the holes overlap. Quote Link to comment Share on other sites More sharing options...
cobblers Posted July 20, 2009 Report Share Posted July 20, 2009 (edited) so if i can get my hubs drilled to 5x100 the pcd adapters to 5x112 it wouldnt stick out tht much and wouldnt be too much hassle.does any 1 know someone who drills hubs?If you are handy yourself, and have access to a decent drill press, I have a jig and the drill bits and taps needed. Got it made up to do mine to fit Audi TT Comps, but lost interest when I couldn't get hold of a pillar drill!The jig is a 6mm steel plate (like a wheel spacer) which bolts on in 3 4x100 holes, and you run a 10.5mm drill bit down the 4 5x100 holes, then tap them. One hole is shared over both 4 and 5 stud.It's close, but should be ok:Drop me a PM if you are interested. Edited July 20, 2009 by cobblers Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted July 20, 2009 Author Report Share Posted July 20, 2009 That's not possible as the holes overlap.he made the adapter witha removable chunk (sounds bad) so the adapter fitted to the wheel but onle 4 bolts were holding the wheel on i thnik. :S Quote Link to comment Share on other sites More sharing options...
16vfrank Posted April 25, 2012 Report Share Posted April 25, 2012 4x100 to 5x112 adapters on eBay Quote Link to comment Share on other sites More sharing options...
Silver! Posted April 25, 2012 Report Share Posted April 25, 2012 3 years later... Quote Link to comment Share on other sites More sharing options...
MiiTCH-TDi Posted April 26, 2012 Report Share Posted April 26, 2012 Loool Quote Link to comment Share on other sites More sharing options...
