Guest Lauryn Posted June 18, 2008 Report Share Posted June 18, 2008 (edited) Looks as though some of the lights on the brake strip at the top arent working, do I need to replace the whole thing or just the ones not working? If so wheres the best place to get it from? I know its OK to leave it like that but it looks untidy and I'm not spending money modding the car when basic things dont work right! Thanks! Edited June 18, 2008 by Lauryn Quote Link to comment Share on other sites More sharing options...
andyp Posted June 18, 2008 Report Share Posted June 18, 2008 you can buy a new one fron vw, or look in the how to guide.. Quote Link to comment Share on other sites More sharing options...
cardaft Posted June 18, 2008 Report Share Posted June 18, 2008 See HEREYou dont need to buy a new light unit Quote Link to comment Share on other sites More sharing options...
Guest Lauryn Posted June 18, 2008 Report Share Posted June 18, 2008 See HEREYou dont need to buy a new light unit Yeah had just came across that! So is it just the wiring or what?! What do I need? Its exactly one half not working, the right hand side! Quote Link to comment Share on other sites More sharing options...
Boy'dup Posted June 18, 2008 Report Share Posted June 18, 2008 Yeah had just came across that! So is it just the wiring or what?! What do I need? Its exactly one half not working, the right hand side!check the bulbs before you hit the wiring Quote Link to comment Share on other sites More sharing options...
Guest Lauryn Posted June 19, 2008 Report Share Posted June 19, 2008 check the bulbs before you hit the wiringRight, I'm going to go out and have a look, what am I looking for to indicate whats broken if that makes sense?! lol Quote Link to comment Share on other sites More sharing options...
Boy'dup Posted June 19, 2008 Report Share Posted June 19, 2008 Right, I'm going to go out and have a look, what am I looking for to indicate whats broken if that makes sense?! lolright, easy way. stand so the suns on the light and run your thumb from one side to the other, the ****ed bulbs usually have a darker shadow than the rest, if not theres a guide somewhere to crack it out, you'll be able to see if theyre broken cos theyre all single filament. (the bit of wire inside will be broken or the bulbs may be darkened on the glass) Quote Link to comment Share on other sites More sharing options...
cardaft Posted June 19, 2008 Report Share Posted June 19, 2008 What i did was, take out the light, use an old steering wheel lock i found in the garage to press the brake (or a friend if you have one handy!) to put the brake lights on. THen if you think yours has a fault, swap one working bulb to a not working one and see if it comes on, it should, then just replace the bulbs that arnt working Quote Link to comment Share on other sites More sharing options...
Petes 16V Sport Posted June 20, 2008 Report Share Posted June 20, 2008 Just a word of advice, I repeatedly had bulbs failing/been dimmer than the other bulbs in the strip, and it turned out not to be the bulbs but the wire from the light to the connector had corroded. New light set and hey presto good as new, but yes, if it is the bulbs you can just change them. Quote Link to comment Share on other sites More sharing options...
Guest Lauryn Posted June 20, 2008 Report Share Posted June 20, 2008 Thanks guys, been a good help! It just puzzled me as its the whole right hand side, like a clean cut down the middle, so I'll check this weekend and sort it from there Quote Link to comment Share on other sites More sharing options...
Scottish_Sport_16V Posted July 9, 2008 Report Share Posted July 9, 2008 How did you get on?I think my one in my spoiler is out all together! Any one confirm if this could be due to a faulty brake switch in the pedal? I know these are prone to failure or maybe i just need a full new bulb addembly? Quote Link to comment Share on other sites More sharing options...
deewhy Posted July 9, 2008 Report Share Posted July 9, 2008 none of mines were working, but the bulbs were ok. rubbed the terminals down as they were all corroded. works fine now. Quote Link to comment Share on other sites More sharing options...
