tomnotrevo Posted March 18, 2008 Report Share Posted March 18, 2008 hey just wondering how do i remove my front grille entirly... iv taken to two starbolts out and depressed the two clips that i can see but it wont come away from the front panel that the indicators sit in!? need to take it out as all my rear badges are now sprayed white and the front is the odd one out! cheers, Tom Quote Link to comment Share on other sites More sharing options...
lupo steve Posted March 18, 2008 Report Share Posted March 18, 2008 P.M sent Quote Link to comment Share on other sites More sharing options...
Jowey Posted March 18, 2008 Report Share Posted March 18, 2008 its easyier to remove the panel below the grill with the grill and seperate them afterwards. the panel is clipped onto the top of the bumper ( which can be unlocked by pushing it up and towards you)there are 2 plug like fittings that attach to the wings by the headlightsthese sit in rubber inserts so a bit of brute force is needed to remove them just be careful not to bend them as they will break Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted March 18, 2008 Report Share Posted March 18, 2008 mine just pulls out, quite easily too! as said, theres about 4 clips on the bottom of the grill, just pop them out, i dont see why you would need to necessarily take the whole panel off?ben Quote Link to comment Share on other sites More sharing options...
sTeVe-O Posted March 18, 2008 Report Share Posted March 18, 2008 there a bit of a bugger indeed, just take your time when putting it back on too as i snapped a few clips off my new debadged one.luckily it still fitted though.so yeah plan of action would be to take your time when your forcing things because as like all the other bits of trim on these cars seem to be made to break when you take it of Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted March 18, 2008 Report Share Posted March 18, 2008 i broke off the bit that screws on when i first got the car! well i had to to get the grill off...was like ah frack ive buggered that up! ive also snapped one of the clips on the bottom of the grill! it seems to hold fine! but i would agree and say take it easy they are only thin bits of plastic.ben Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted March 22, 2008 Report Share Posted March 22, 2008 yep i just put a crack in the grill :@2 much brute force.still not off Quote Link to comment Share on other sites More sharing options...
heartagram Posted March 22, 2008 Report Share Posted March 22, 2008 I always wrap a screwdriver in masking tape and put it on either edge of the grille and pop those clips out of the sides. Then just shimmy the rest off. Quote Link to comment Share on other sites More sharing options...
tomnotrevo Posted March 23, 2008 Author Report Share Posted March 23, 2008 sorted!... got it out, got the badge our, separated the chromed part from the back black part, keyed it up, preped it for painting, sprayed it gloss white, left to dry, everything back together and the grille back in, with a bit of hassel but no broken bits at all!! so pretty much good going by the sounds of things! Cheers for all the help guys! Quote Link to comment Share on other sites More sharing options...
